Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-16-2007, 08:58 PM
Ranchero con queso is starting off with a positive reputation.
Angry 73 Ranchero problem
My 73 Ranchero 500 (302) likes to shut down while driving. Then it will crank without a spark and not start for a few hours. Then, everything is fine again and she's in a good mood. Since I'm not much of a troubleshooter, I've just been replacing old parts and hoping to get lucky. So far, I've replaced the coil, points, condesor, cap, rotor, plugs, wires and carbuerator. What now?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-18-2007, 07:33 PM
fl1a is starting off with a positive reputation.
One more important component in the ignition circuit is the ballast resistor for the ignition
coil. If your spark quits when your engine compartment gets warm, it might be failing.
Thermal expansion and contraction over the years can cause them to fail. If you have a
meter, you could check its' resistance when you are getting spark, and when you get
no spark, or you can test by substitution.
  #3 (permalink)
Old 12-18-2007, 07:45 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
Welcome to FTE
Throwing money at the issue is only making you poorer, you need to have the problem properly diagnosed.
If you are in the SoCal area, call Bill at Bill's Auto Repair in Orange (714-639-3410). He is the BEST darn mechanic around on older Fords. He does most of the work for the SoCal Galaxie club members, and has done work for me. I highly recommend him.
There are other factors to consider. One is the ballast resistor (wire) mentioned above, others could be a bad ignition switch or point plate..and etc.
The ballast resistor is actually a wire on these models. Ignition switch to coil.
There's two different ones listed for 1973 Ranchero's.
It's prolly the first one, but who knows after 34 years what's been swapped around?
D1AZ-12250-A .. Ignition Coil Ballast Resistor Assy (Motorcraft DY-84-A) #16 gauge wire / color code red with green stripes / 1.30 to 1.40 ohms / 60" long.
D7AZ-12250-A .. Ignition Coil Ballast Resistor Assy (Motorcraft DY-213) #16 gauge wire / color coded red / 49" long.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #4 (permalink)
Old 12-18-2007, 10:51 PM
Thanks. I will attempt to locate that ballast resistor first. I'm not brave enough to try to drive this puppy all the way to Orange but if I'm in that area, I will definately go see Bill and let him know he's spoken highly of. I appreciate the help.
  #5 (permalink)
Old 12-18-2007, 10:58 PM
Thank you very much. Although pushing this Ranchero is a great workout, I'd much rather drive it from now on. I will hunt down that ballast resistor.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
