Durn nice that you live in California where they are. I called them a while back and asked if they could sell one and let a local shop put it in, but they said no way. I drool to get one of those.
By the way, it is a 44 gallon tank See the pdf at the link below.
if you burp the tank you can get more in, I've put in almost 46 gallons once. something like 45.8???.....isn't that what the harpoon mod is for? I'm trying to never do it again!
__________________
Black '05 Excursion PSD Limited 4x4.
Built 9/26/05, purchased 12/1/05.
Airaid intake with "zoodad" mod, MBRP 4" Turbo back, no kitty & Bully Dog downloader, Acufab power elbow, Mag Hytec F & R diff covers & trans pan. Helwig rear sway bar 50k miles.2" Hanger leveling lift. Bilsteins, 20x9 ProComp Extreme Alloys w/ 305/55R20 BFG All terrains
My Toy Hauler ways 13,000 pounds. We ordered the Toy Hauler with flipped axles but from a side to side comparison about 8 inches taller than a non flipped Toy Hauler. I have a horrible problem with sway but I hope my new Equalizer hitch will fix that but I don't know yet because the first trip we were going to take it out on we got into a car wreck. But we had a TT before this and it came with it normal and towed great and then we fliped the axles and it tows a little worst but then we added a sway bar and all was good.
__________________
-Nick
Worlds Youngest Power Stroker
PAA#9
04 X 6.0
08 mirrors, 15,000 trailer hitch receiver, Fire stone air bags
01 X 7.3
6637, 05 head lights, MBRP 4in Exhaust, Running boardlights, Cab lights, Dipricol Gauges Boost, Pryo, Trans, Dp tuner, Powerslot rotors and Hawk LTS Pads, OBA, WW
Thats bad for your emissions system, you get raw fuel in your charcoal canister and can get it up into lines with valves that are only meant to move fumes not liquid. Kinda frowned upon, but once or twice probably wont kill you if your leaving on a trip immediatly. I woulndt exactly suggest it though.
I don't want to hi-jack this thread so I'll start a new one...........
__________________
That hitch definitely looks strong. However, I am just curious Is that hitch welded to the frame? I was wondering because I thought that the hitch needed to be able to flex or it may damage the frame.
The eckhart hitch is indeed welded to the frame...well it's a bit of both. They acutally weld part of the hitch to the frame and leave the angle iron (part of the original hitch) that's bolted onto the excursion frame...and weld their hitch to this as well. Hopefully that just made sense....
We just had a hitch from Eckharts installed in March of 2008. So far I've been real happy with the unit.
__________________
2000 Ford Excursion - V10, 4:30 axle, 4x4
