2008 Block Heater?
it is an options if you do not live in the cold states that ford specifies, if it does not have one then you can buy the cable at ford since they claim all superdutys have the heater just not the cord unless you get the option or the truck was shipped to one of the cold states from the factory
there should be a small plug-in in one of the freeze plugs on the engine block, try getting under the truck and looking for the plug in, if you see a wire running from the block to somewhere, track it down and it could be the heater cable already installed, if not and you see the plug-in in the block then you can buy the cable from ford for around $35, or what you would pay for the option on the truck
I am actually speaking from personal experience. Seattle does not get to those temps but east of the mountains does(the rest of Washington State)as well as my cabin one hour from here. I needed one, forgot to check the box when I ordered my truck this time. Usually I don't forget. The cord is 90 bucks but is much easier to put on then it was on the 6.0 liter. Ford is cheap and does not include as many states as they should. Also, this thing takes forever to warm up. even if it was 0 degrees its nice to have your coolant warm up quicker and yes I have the supplemental heat but I hate starting my trucks 45 minutes early to get them warmed up. You ever go to Mercedes Red Dragon? I used to go there when I was a kid to have a few cocktails.
jr
idiabuse
11-29-2014 01:26 PM
jhaas63
07-14-2014 07:14 PM
blueeyedfordguy
General Diesel Discussion
12-16-2013 02:22 PM
