Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-16-2007, 05:05 PM
bookum1 is starting off with a positive reputation.
Ping Ping Ping!!! Help Help Help.
I have posted before, but any help would be appreciated. I have a pretty bad ping or "spark knock" at about 1400-1700 rpms and sometimes higher when I strain the enging accelerating. It is a lot more pronounced with load. Recently I have changed the plugs, air filter, fuel filter, cleaned MAF, fixed broken exhaust bolts and check for computer updates and there where none. I have no codes and doesn't have any other problems. I know this cannot be a normal condition
I don't think other than put a new engine in I can do anymore.
Any one have this problem and fix it
Help!
__________________
2001 F250 V10
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-16-2007, 05:33 PM
omni's Avatar
omni is starting off with a positive reputation.
I don't have a v10, but I have to run a higher octane in my truck or it pings under load. I can get away with a mid grade, but it does work better with the premium
__________________
1994 f150 XLT 4x4 5.8 E40D
1987 f150 XL 4x4 5.0 AOD
1978 Bronco XLT 400 C6
  #3 (permalink)
Old 12-16-2007, 06:29 PM
swann79's Avatar
High-tech Redneck
swann79 is gaining momentum as a positive member of FTE.swann79 is gaining momentum as a positive member of FTE.
Have you tried a different brand of fuel and/or higher octane?
I recently switched my usual gas station because all of a sudden all of my vehicles were pinging, no matter what octane I was running. After the switch, everything went back to normal!
__________________
*Scott*
2001 F-250 CC, SB, Lariat, 4X4, 6.8 V-10... "BSEG Club"
17 other Fords '62-'05, Trucks, SUVs, Vans, Mustangs... all sold or dead!
Powder River, let 'er buck!
  #4 (permalink)
Old 12-16-2007, 06:34 PM
I have tried many grades, and many stations. Only 93 octane helps. However, the truck is designed for low octane fuel. I am going to take it to the dealer to see if they can tell me if there is actually a problem
__________________
2001 F250 V10
  #5 (permalink)
Old 12-16-2007, 06:53 PM
swann79's Avatar
High-tech Redneck
OK after looking at your previous posts I do remember your issue.
Did you try the Seafoam treatment? I know not everyone on this board agrees that it's a good idea, but I've done it plenty of times. Sometimes with good results, but never with bad. My thinking is you've got some carbon buildup in the combustion chambers which is raising your compression ratio high enough to ping with the lower octane fuel.
Seafoam MAY help, but if not, the only cure is to pull the heads and do some cleaning.
__________________
*Scott*
  #6 (permalink)
Old 12-16-2007, 11:42 PM
rvpuller is starting off with a positive reputation.
I see you have a 2001 if its a early production it may have the older Y pipe. the old style will cause a knock at the RPMs you are talking about and it gets worse the more load thats on the motor.
Denny
__________________
2000 F350 Lariat SC DRW V10 4.30 Gears BrakeSmart
Air Lifts 4X2
2003 HH Premier 35 FKTG
BSEG started 4/15/2000
  #7 (permalink)
Old 12-17-2007, 12:08 AM
it has the old constricted y-pipe. I was thinking of changing it to the ebay pipe, but how could that cause the ping?. I should have mentioned too that I had the dealer do a three stage carbon flush. It is my understanding that the ping is caused by fuel octane and compression pressure. Mine almost soulds like what I always thought was valve chatter, but I think it is also called spark knock.
__________________
2001 F250 V10
  #8 (permalink)
Old 12-17-2007, 12:24 AM
biz4two's Avatar
biz4two has a good reputation on FTE.biz4two has a good reputation on FTE.
Arrow
You mentioned that you changed the plugs. What brand plugs did you go with? How many miles on your V10? What mileage did you change the plugs?
IMO...The best thing that can be done...is to have the dealer have the portable computer do a "live capture" while driving your SD. They can have you drive around for a week...then bring it back and evaluate the data captured.
Believe it or not...it could be your O2 sensors, but without "capturing" the data...pretty hard to say.
Good luck...
biz
__________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #9 (permalink)
Old 12-17-2007, 07:41 AM
MarkMoore's Avatar
MarkMoore is gaining momentum as a positive member of FTE.MarkMoore is gaining momentum as a positive member of FTE.
Have you changed the fuel filter? V10s are pretty fuel pressure senitive, if the filter is cloggin, then it can cause a 'ping'. A cheap fix.
__________________
- The Urban Assault Vehicle -
2001 Excursion Limited, 4x4, V10, 3.73
RoadMaster Active Suspension
2001 Prowler 31G
Equal-i-zer WD Hitch
Prodigy Brake Controller
  #10 (permalink)
Old 12-17-2007, 09:22 PM
did change filter, what else
__________________
2001 F250 V10
  #11 (permalink)
Old 12-18-2007, 12:17 PM
dkf's Avatar
dkf dkf is offline
dkf is gaining momentum as a positive member of FTE.
I would find a local SCT or Diablosport dealer and go to them to have your truck dyno tuned. They can put your truck on a chassic dyno under load stick a wide band o2 sensor in the tailpipe and monitor everything in real time under load. There is a good chance they can adjust the air/fuel ratio, timing and etc to get rid of the ping.
I would at least find a shop and tell them your situation and see what they suggest.
  #12 (permalink)
Old 12-18-2007, 07:36 PM
900rr is starting off with a positive reputation.
i have a 2000 and mine just started to ping and i had asked on the forums about valve chatter as well when you find a cure let me know and i will do the same my next question in were do you live i live in up-state ny and am wondering as to gas and what they may be adding or not adsding to there fuel
__________________
2000 cc super duty v10 3.73 cc lariat 4x4 tan short box
  #13 (permalink)
Old 12-18-2007, 10:11 PM
I live in North Louisiana. I have had other vehicles that have had minor chatter and the v10 is not bad, but surely there is a fix. It runs great, but something is going on and I have tried everything suggested except an o2 sensor. The dealer tells me that since there are no codes than they cannot help me.
__________________
2001 F250 V10
  #14 (permalink)
Old 12-19-2007, 12:24 AM
3000 FPS is starting off with a positive reputation.
I thought most engines had a knock sensor that is used just for this very thing pinging. I was under the impression that it would retard the timing to eliminate it. Just another possibility if the sensor was bad.
  #15 (permalink)
Old 12-19-2007, 01:12 AM
I don't know if the 2001 v10 evan has a knock sensor
__________________
2001 F250 V10
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
