Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-16-2007, 02:29 PM
tire26 is starting off with a positive reputation.
mustang 2v 4.6 --> 3v 5.4 truck motor
i have found very few people that have done this swap. the 4v or 2v 5.4's are a more popular swap, but that's not how the cookie crumbled.
goal:
swap in the 5.4 for as cheap as possible, making no upgrades unless neccessary to replace said part anyways.
what i have:
*00 gt 5spd (stock)
*a low mileage 2005 3v 5.4 f-series truck motor, complete from oil pan to air filter, wiring harness, computer, fly. just lacks accessories, but i'm hoping to reuse some of my 4.6's.
i'm going into this swap nearly blind. my goal is bang-for-the-buck performance. this translates into i just want the motor in the car for now. suspension tuning/lightening the car/bolt-ons, etc. will have to wait a long time. i got the car (wrecked) for a total of 500$ and the 5.4 for 600$... are you getting the picture yet? btw anyone interested in a v10 triton motor?
so far i have a battery relocation kit i'll be installing when i return to cali. the battery is a truck battery with 700+ cca's so no problems there.
it turns out a 4" cowl won't cover the intake... the 5.4 is 6.5" taller than the 4.6. i'm still unsure what to do for a hood, but as the car is going in for paint relatively soon i'll have to address that before the motor swap beings. i have become decent at fiberglass repair and sculpting, so i may turn it into a mach 1 type shaker-ish looking hood and just cut my stock hood. i don't want a 6"+ rediculous hood on a slow daily driver.
Q's:
*the tb is fly by wire aka no cable. i understand that this will further complicate the swap and i would prefer a regular tb anyways. will this cause a complication with the computer to put a regular tb on?
*i'm replacing the motor mounts, but i want to know how the aftermarket ones differ from the stock replacements. and if the price difference is small enough to warrant buying the aftermarket ones.
*the tranny will bolt right up to the 5.4 as the 5.4s are just taller decked 4.6s, but is there anything in this dept. that i should know about? the fly is an 8 bolt btw not a 6 like stock.
*being that the engine is complete and has the computer and everything pretty much i'll need to get her at least running, would a custom tune be recommended? i imagine most reading this would respond that yes, of course, but keep in mind the tune would cost as much as what i got the motor for. and 365tq on 87 octane is plenty for me at this point! however, will the power curve be so tq-heavy and low revving that it'd make the car a pain to drive? i guess i will just have to find out... but if anyone has experience in this area, i'm all ears.
*will the stock cooling system be sufficient? the only change planned is a 55gpm meziere elec. water pump.
*will the oil pan fit w/ the stock k member?
i may keep this thread alive over time as i have more Q's, if anyone with experience or knowledge feels like advising.
austin
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-17-2007, 11:27 AM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
I know in the V10 forum we get a few people asking about a 3-valve swap from time-to-time.
Everyone's answers are generally "buy a new truck with the 3-valve in it".
The PCM is going to complain about all sorts of things, not just the throttle-body if you change it.
The 3-valve PCM is linked to the ABS and airbag systems much more tightly then previous models. Without the entire electronics from the 3-valve system, you're going to have problems ... but you can't do that without changing like EVERYTHING.
Is this motor out of an F150 or Superduty?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Volant CAI, eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #3 (permalink)
Old 12-17-2007, 11:51 AM
i don't know. all i know is that it's from a truck and has a tall as heck intake.
what do you mean that the pcm is link to abs and airbags? thanks.
austin
  #4 (permalink)
Old 12-17-2007, 12:06 PM
krewat's Avatar
Quote:
In the Superduty, and probably the F150, the PCM talks to the air-bag and abs modules. If the PCM doesn't see those systems, it will light the check-engine/SES light. It won't know how fast the vehicle is traveling, because it gets that data from the ABS system over a new network called CAN (Controller area network). There's other stuff, but you get the idea.
You might be able to get a custom tune to do away with that stuff. I'd call the tuner/chip companies and see if they have a custom tune for a 3-valve stuffed into another vehicle.
If they do, definitely report back
__________________
  #5 (permalink)
Old 12-18-2007, 03:08 AM
thanks krewat i'll make a note of that.
  #6 (permalink)
Old 12-18-2007, 07:16 PM
92f150I6's Avatar
92f150I6 is starting off with a positive reputation.
Just a thought, can you run the 3 valve motor with the 2 valve electronics?
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
A bunch of motorcycles, other cars, and a Quad.
  #7 (permalink)
Old 12-18-2007, 10:45 PM
krewat's Avatar
Quote:
I know the V10 has a variable-volume plenum (intake). Somewhere in the RPM range, depending on load, the PCM opens or closes a butterfly between two sections of the intake.
It basically turns the long-runner intake into a short-runner intake. Which transforms it from a low-end-torque intake to a high-end-torque intake.
You could, theoretically shut (or open) that butterfly permanently, and run it that way. But you'd lose the benefit of the 3 valves.
Not to mention, if this is a 5.4, it's got VVT - variable valve timing. How do you control that with a 2-valve PCM?
__________________
  #8 (permalink)
Old 12-18-2007, 10:46 PM
krewat's Avatar
Quote:
Hmm... shouldn't have said it that way.
What I meant to say was, you'd lose the broad torque curve...
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
