Instrument Cluster
Instrument Cluster
Hello all,
I was wondering if I could put the instrument panel from a '94 Lightning in my '94 F150. I have 3.55 gears and I'm not sure what rear end the '94 lightning has. I like the fact that the lightning's panel has a tach and white faced gauges. Would the rear end gears have to match up in order for the switch to be possible?
Thanks
Thanks
Instrument Cluster
The switch is possible but why only use the Lightning guage panel? They do make white face kits for the 92-96 regular trucks if I'm not mistaken.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Can see both below.
Instrument Cluster
Thanks for the reply...
I'll check into some of those aftermarket white faced gauges. I've seen a few and they all have either blue or red numbers on the white background. I kind of like the black on white. Either way, if I can't come across the cluster from a lightning, I'll probably have to go aftermarket.
Thanks!
Thanks!
Instrument Cluster
If you've got the Vehicle Speed Sensor located in the diff housing (and I'm pretty sure you do) then the speedo looks at the ring gear rotation and ignores differences in ratio (the Gen I Lightnings were geared 4.11.) You will have to reprogram your module to accomodate your tire diameter if it's different from the Lightning's
toyhunter1955
08-17-2009 09:01 AM
crestfallinman
08-21-2008 11:58 PM
crestfallinman
15
01-03-2008 08:02 AM
lightning94
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
10-29-2007 11:15 PM
Johns331
09-05-2002 11:45 AM
