F250 Front Door Speaker Size??? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-15-2007, 12:47 PM
greagin greagin is offline
greagin is starting off with a positive reputation.
Anyone know the size for Front Door Speakers in a 2001 F250? My drivers side quit working and i need to replace but before taking apart i was wondering if anyone knew what size speaker to order?
Old 12-15-2007, 01:20 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
I think they're 6x9s. But it takes two minutes to get the door panel off. Take the plastic cover off the top, front side that hides the mirror mounts (pull straight away from the door). Pull up on the power window/lock switches & remove connectors. There is a screw under there. Remove it. Pull the reflector/light off the bottom rear part of the door using a screwdriver -- there's a second screw there. Then just lift straight up on the panel and it will come off. That's it...
This thread contains the same instructions, but also has a link to pics, if that helps:
http://www.ford-trucks.com/forums/68...oor-panel.html
Old 12-15-2007, 01:52 PM
AustinS AustinS is offline
AustinS is gaining momentum as a positive member of FTE.AustinS is gaining momentum as a positive member of FTE.
The stock front and rear speakers in my '01 supercab were 6x8's.
hope that helps,
Austin
Old 12-15-2007, 02:12 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
5x7 or 6x8 will work. 6x9 is too big.
Old 12-15-2007, 02:43 PM
Izzy351's Avatar
Yeah, I couldn't remember since I really wasn't looking at 'em. I was focused on the power window tracks behind it all. BTW, if you're looking at different speakers, you really should pull the panel and measure the depth if nothing else. IIRC, there ain't a lot of space back there...
Old 12-15-2007, 03:18 PM
kupaa's Avatar
kupaa kupaa is offline
kupaa is gaining momentum as a positive member of FTE.
its 5x7 just changed mine.
Old 12-15-2007, 06:31 PM
thanks ! what kind did you go back with? and what was the speaker depth if you know. i was going to buy some 5 x 7 3-way blaupunkts off of ebay for $30. what do you think? its just the factory stereo so i dont need anything to jam per se, but i would like crisp clear sound quality.
Old 12-15-2007, 06:38 PM
RogueSpear2023's Avatar
RogueSpear2023 RogueSpear2023 is offline
RogueSpear2023 is starting off with a positive reputation.
Ya it's 5x7 just did mine as well, I have JL audio XR series in front, and elclipse point sorce in the back(out of my 02 Focus) I had a pair of eclipse intergrated in the back of the Focus, but they cost more to remove then they worth so I left them, when I traded it. Are you going to upgrade your radio at some point or did the factory speakers just die?
Old 12-15-2007, 07:26 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
I bought some Pioneer TS-A6840R's on eBay, and I'm quite happy with them. The ones currently available there are now TS-A6870R.
They are 6 x 8's, and made specifically as aftermarket for Fords and Mazdas. They're bolt-in.
Pop
Old 12-15-2007, 08:09 PM
kupaa's Avatar
Quote:
I have the infinity kappa series and the sound is real crisp,but like springerpop said i would go with the 6x8 they are also a direct fit and would sound better then the 5x7 since there bigger.
Old 12-15-2007, 09:00 PM
justblowin'smoke justblowin'smoke is offline
justblowin'smoke is starting off with a positive reputation.
check out crutchfield.com they have good deals on speakers, subs, amps everything thats where i got mine pioneer's in the doors and kenwoods behind the seat clear and crisp sound love them
Old 12-15-2007, 09:03 PM
i dont intend to upgrade the stereo. 15 years ago, yes. you all don't by chance know what the depth of any of those speakers were do you?
Old 12-15-2007, 10:07 PM
Quote:
the bigger isn't always better, quility is what you want look for in a speaker not size. The 6x8 won't always better, My 5x7s will beat the pants off of most, 6x8's out there, not only in volume, but in quality as well.
Old 12-15-2007, 10:32 PM
bdrummonds's Avatar
I have these 5x7 Blaupunkts, of course 3 years ago when I bought them they were not $30 a set, more like $150 a set. I have a set in my doors, and another set in the rear. The sound is very clear, no distortion. great speakers.
Old 12-15-2007, 10:46 PM
thanks for the information!!! that's the reply i was hoping for from someone. I am going to fleabay and ordering them now!!
Stock sound system upgrade questions. Diesel 724 1999 - 2003 7.3L Power Stroke Diesel 18 01-09-2015 01:38 AM
Stock speaker sizes? Walwal44 1987 - 1996 F150 & Larger F-Series Trucks 2 02-27-2014 12:14 PM
Speaker size 1997fordf350 1987 - 1996 F150 & Larger F-Series Trucks 6 08-01-2012 11:31 AM
Speaker Sizes pmasley Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 9 01-21-2006 01:14 PM
What size are the door speakers in '04 F-250 Saxon Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 07-28-2004 11:46 PM
Tags
06, 1999, 2002, 2004, 2008, 95, door, f250, ford, front, removal, size, speaker, speakers, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
