12-15-2007, 07:05 PM
38 Rich, Unless you purchase one of the new aftermarket units you probably will find that nothing will bolt right in without some modifications. I think the thing you will have to check is the length of the column making sure it will reach through the floorboard to hook up. I think a lot of hotrodders use columns out of vans because they are longer. I intend to try and use the original column in my 46 even though it has a mII ifs and 302. I'll have to cut back the outside install some kind of bearing and put a u-joint on the shaft, then figure out how to hook it to the rack. Sometimes you have to be creative.
