Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-14-2007, 09:42 PM
snaxforgandhi is starting off with a positive reputation.
Arrow Stupid Coil Question, take 2: No Big Scary Words
'94 Ranger XLT Lariat, 3.0 V6 OHV, 4-speed A4LD
OK, let's try again, this time with no big scary words.
Truck "stutters" when cruising. Happened to look under hood when it was dark and noticed some faint blue arcing around coil and along coil wire. Seems logical that spark may be shunting to ground: Not my question.
Question: Is it normal to see some trace arcing around ignition coil if viewed in complete darkness. I obvioulsy understand that sparks should not be shooting out of the coil, but this is very faint, so faint that it is not visible under normal lighting. So, I'm not sure if what I'm seeing is weird, or just some kinda side effect that's normal for high-ratio x-formers like ignition coils (sorry 'bout that last bit, I know I promised no big scary words. But if you don't know what I mean by high-ratio transformer then you probably don't know the answer to my question. No harm, no foul)
What I am looking for here is someone who can speak to theory (I know, I know... scary) or who might have had seen something similar. Though appreciated, the "spray with goo" fix isn't really helping me.
!!!NOTE!!!: If you understand terms like "flux," "potential," and "static charge," and think you might benefit from a more complete explanation, please see my original post here:
http://www.ford-trucks.com/forums/684066-possibly-stupid-definitely-long-coil-question-cmon-i-dare-you.html
Any help will certainly be appreciated! Thanx for your time!
Respectfully, ~G
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-21-2007, 08:48 AM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
Measure the resistance on your coil wire. Spray with a bit of water mist and really
see the sparks a flying. I covered all my plug wires with split loom because I had
quite a few spots that were arcing to ground or to low voltage wires. Plug wires
should measure out to around 5000 ohms per foot If you find that it is substantially
more then this, Electricity will find the path of least resistance!!
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
  #3 (permalink)
Old 01-08-2008, 12:51 PM
kittrell is starting off with a positive reputation.
1999 Ford Ranger V6 3.0
What is the wire order on the coil pack
1 6
2 5
3 4
or what???
  #4 (permalink)
Old 01-09-2008, 03:30 AM
No coil pack, just coil. Single coil wire from coil tower to distributor tower.
Thanx for the input folks. I got 'er figured out!
~G
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
