Tearing into the 6.9.....
#31
Here is the bottom of a head.
The small hole right below the valves, in the dark circles on the left three cylinders is the precup.
The precup pops out.
The piston crown at top dead center is the thickness of the head gasket below the head, which is flat on the bottom.
#32
Dave them are niec pictures, i would have never imagined the bottom end of these looked so beefy!! them mains are massive! wow no wonder it handles all my abuse!!! Thank you very much for the pictures!!
i do have one other ? though.. do you know what the DRY weight of a ready to run 6.9 non turbo engine is? to be more specific.. with block, heads and intake , ip and such.. everything but liquids and accessories, like alt, power stteering pump, vacuum pump...
also is it normally necessery to replace head bolts when you blow a head gasket?
Ray
Ray
#34
#35
Ray
Ray
#36
#37
I am going to say a bit over 1000 pounds.
The figure I normally use is 1200 pounds.
I have a heavy duty engine hoist, tow behind model it is so big.
It will not pick the engine up when in the 1000 pound position.
The 1500 pound position gives the hoist about all it wants just getting the oil pan over the front bumper.
And even though it is as wide as the truck, the legs just go inside the front wheels, I will not raise the engine over the radiator shell with it.
To much weight way to high in the air on my 4x4.
When I use an engine hoist, the radiator shell comes off the truck.
To go in the top, it has to be on a chain hoist attached to something very solid or I want nothing to do with it.
To much twisting and turning the engine to get it in and out going the top way so it will clear the radiator shell unless you leave the crank pulley and water pump off till it is in the truck.
Then you have to stand on your head to install them.
#38
#39
on
Yanked mine with a 1.5 ton chain hoist that was attached to the main beam of out shop, since we have a 13F ceiling, the engine came out easily without removing the core support, But I'm not sure if I can get away with that if I have the turbo pack on when it goes in. The beam in the shop was fir 2x12 stacked 4 and less than 4 feet from a steel pillar.
#40
I have installed mine with a chain hoist with the turbo and turbo up pipe on the engine.
I also had the water pump and crank pulleys on.
You have to turn the engine front to the drivers side about 50 degrees, then lower it untill the water pump shaft is below the top of the radiator support before you turn it like it is supposed to sit.
Oil pan and cross member, water pump and radiator support, turbo and firewall are the three main trouble spots.
Once you get the engine wrestled into place, you will see why I don't feel comfortable using a cherry picker type hoist going over the top.
#42
Ok, I rechecked the weight of the 7.3 at work today and the shipping tag said 994lbs with the pallet. this was the t444e engine with the turbo mounted. I don't believe the idi weighs more than this engine. The diesel stop says the dry weight is 920 lbs for the t444e also. I know it feels like alot of weight. On the 1/2 ton setting, i have to hold the hoist so it doesn't tip over. All the acceseries and brackets, fly wheel , clutch ect probably add more than 200lbs but as for dry weight I think its around 900lbs
#43
I'm with Dave on this one. Maybe our lifts have been used too much in the past but my standard engine lift (Marked by the mfg as a 2 ton.. lol.. right) began to bend on me when removing my engine. I ended up using my chain fall mounted to the steal beam in my garage. I also removed the radiator and condenser but left the core support.
#44
