You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hello everyone.
I am here trying to keep my expy alive for a few more miles. Seems like I hit 100k and a switch went off...now I'm on a 1st name basis with the AAA man. Thanks in advance for all your help.
You may want to go into 'User CP' and add your location and add information about your Expedition ( engine, trans, 2wd/4wd, prior problems, etc...). That will help us help you. (Think Jerry Maguire... )
The truck doesn't like the wet weather @ all. Hard or no start when we get rain, which isn't that often so I have ignored it in the past but recently it has been more of an issue. Recently the truck stranded my wife but managed to start again and limp home. Then a couple days ago it came home on the hook. I looked through the forums here found some common issues and knocked them out today. I needed a new battery and that led to new terminal connections. Totally worth the :45 minutes to clean everything up and install the new ends. So now I had full cranking power but no fuel pump noise so I dropped the tank and swapped out the pump and filter. The truck started right up so hopefully I killed the problem. All in all I am in maybe 4 hours of time and 297$ and everything seems to be working fine.
Now I just have to wait and see if the problem comes back. Hopefully it won't and I'll forget allllllll about it
Does anyone know if the moisture/rain issue is in any way tied to the fuel issues I just addressed? I read something about the GEM module getting wet?
