Temp gauge showing cold
Still trying to figure out dramatic drop in fuel mileage since cold weather showed up.
I had someone go over the fuel pump and intake lines, injection lines... pretty much looked over everything and could find nothing to show a fuel leak. What he did notice was that the temp gauge barely moved off the C even well after it was warmed up and blowing heat. The truck makes plenty of heat but he thought maybe the thermostat was opening to soon to allow it to run hot enough to burn correctly and we just never had an issue during warmer weather. Is this possible or is there some other place we should look? Would there be a sensor or something that would allow it to run cold? Could the gauge be the issue and there's another reason for the lousy mileage???
Winter fuel seems to burn faster for some reason,and the cold weather also activates the EBPV which will give you terrable milage,if the truck is blowing heat it is running normal like already said the stock gauges suck,there would be a problem if after it had been running a while and was still blowing cold air this would give poor milage
Fuel, warm-up.. all stuff I'm aware of as I've either been in a big truck or my pick-up for the last 22 years. Still, this is the 3rd 7.3 I've had and I've never had this issue before so one would think that there is a logical explanation. A slight drop is one thing, a 35% cut is another. Don't you think?
Maybe I'll disconnect the ebpv and see if that makes a difference.
Wonder if this temp would play havoc on a map sensor. Its just a thought. Its a easy check too. Have another thing that people commonly overlook is tire air pressure. Although you say it happened overnight, it can still get you 1 to three, depending. Have you cleaned the FPR screen? Maybe its plugged? Fuel Filter? Just a few of the basics I am throwing out there. you will see it drop 3 mpg just from the switch in fuels. another thing a lot of guys do, is try dumping a qt of tranny fluid into the fuel. 1/2 in front tank, 1/2 in rear on a fill up. Then check your FPR and filter after you run those tanks out. It will loosen a lot of the junk that kills mileage, plus its lubes injectors and such. You have no wetness in the enine valley, correct?? Hope you find it.....
Scan Eot ,& see how it compares to ambient air temp,, check the fuel pressure ,, See what up....
If the EBPV was stuck , it would effect milage , but also performance....
geldingmakr
1997-2006 Expedition & Navigator
01-09-2011 08:28 PM
