Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-13-2007, 04:29 PM
Cheshire Cat's Avatar
Cheshire Cat is starting off with a positive reputation.
2" body lift
Hi, i just bought a 2" body lift for my 74 bronco. Is there any tricks or anything else i need to buy befor installing the lift or will everything still work right? thanks for any help...
__________________
1969 i think. Has a '74 glove box, 302, 3 speed on the floor, f150 springs up front, 2in lift leafs rear, 1966 Mustang 302, c4. Both under construction..
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-14-2007, 12:59 AM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
I would recommend replacing the body mount bushings with poly when you install the body lift.
Soak the body bolts with penetrating oil a few times a day or two before you plan on doing it. And use a wire brush or wire wheel to clean the exposed threads. Will make a big difference on how easily the bolts come out.
The original bushings have metal washers and sleeves. The top sleeve fits into the bottom and holds it to the frame. A trick I learned is to use a punch that will just fit into the lower washer and drive it upwards toward the body. In most cases, they should come apart easily this way.
If you have a manual trans, the clutch linkage will need to be lengthened. There are upgraded extended linkages available that are much stouter than the L shaped factory version. If you have a column shift or an automatic, you will need to lengthen the rod.
You may need to adjust the steering column to reach the steering box. In some cases, you may need to do some changes to the steering shaft. The rag joint can be put into a bind which can cause premature failure and steering bind.
You may need to change the throttle linkage, but not in most cases.
You will need to cut out the bottom of your fan shroud or replace it with an aftermarket steel version.
You will want to loosen the clamp that holds the master cylinder hoses and readjust the length as needed.
With a 2", you may need to extend your fuel filler hose on the main tank. When I did mine, the fill hose was fine, but I had to put on a longer vent hose.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 12-23-2007, 01:30 AM
Tim Young is starting off with a positive reputation.
Quote:
Cool, I just bought a full kit myself body mounts and all. I have not started yet but seems pretty straight forward. I will follow along to see how it goes as I won't get started until next spring with mine. Sense I am driving it to work these days.
Tim
__________________
1997 F350 Crew Cab, 7.3L Power Stroke, The Luxury Liner
1968 F250 Camper Special, 390, The Wife's Truck
1969 Bronco, Work in progress
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
