Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-13-2007, 12:15 PM
Hobbybigred is starting off with a positive reputation.
MAF issue/ computer tune
Just thought Id drop in and see if I could get a second opinion on this. I have a 92 F-150 302 and a few months back, when idling, it was really rough and would flucuate between 1000rpm to 500 rpm and eventually die out. I pulled the plug on the MAF sensor and now it idles but OF COURSE is running really lean. I keep replacing the MAF with junkyard MAFs (mainly from 93 mustangs). I know that this can be really bad for the motor since the ECC reads that to tell the motor what to do (ie fuel/air ratio). Since a new MAF is pretty expensive would I be better off just hooking back up the sensor and get a computer tune and see if that will fix the issue?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-13-2007, 02:11 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Reconnect your MAF meter and pull the codes from the computer, that should always be the first step when troubleshooting an EFI motor. On a side note, idle problems on these motors are often related to a dirty IAC(idle air control) valve, rinsing it liberally with carb cleaner while the engine is running often smooths things out.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #3 (permalink)
Old 12-14-2007, 06:37 PM
thanxs a bunch. Took off the throttle body cleaned it up a little (lot of build up) cleaned the IAC, delayed the timing just a bit and it puuuuurrrrsss like a kitten along with that nice chop to go with the cam
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
