EDELBROCK FORD 300 INTAKE
I saw one on ebay a while ago. I didn't know they made one with all the stock stuff on them. At least they used to but not anymore. Does anyone have any experience with them? Are they a waste of time with the one barrel carb? Just curious. It is sort of interesting since it looks smog legal and I'm in CA. I figured with some smog headers and a new ignition, I might be able to see some gains in power.
'84 F150
YFA F/B
SROD
"Ex" => Bone Stock
'84 F150
YFA F/B
SROD
"Ex" => Bone Stock
Dont know about the edelbrock, but offenhauser C series bolts right up to the stock exhaust manifold. Tried the one barrell(with an adapter plate that I made) but did not notice any difference in power. Switched to the 500cfm edelbrock carb and with header installed it made a big difference, but, no smog checks for 25 year old trucks in Oklahoma. I have heard that 390 or 450 hollies tune well with the 300cid engine.
1977 F-100
300 I-6 / C-4 (soon to be AOD)
Offy intake w/Edelbrock 500CFM
Hooker Ceramic coated headers w/duals
MSD6
Whiter whites/Brighter brights
1977 F-100
MSD6
rpspwp:
Before you do any modifications to your truck's engine, make sure you can modify it. Check with state laws first. California isn't very friendly from what I have heard when it comes to dealing with people modifying there vehicles.
1994 Ford F150
300-6
Highly Modified and more to come!
1994 Ford F150
300-6
Tried offenhauser c series intake. Looks better than it works. Some performance gain, especially with a 4 barrel, but tuning will be a problem. Fuel seems to condense inside those nice long runners,and rear cylinders burn too rich as the fuel runs downhill inside the intake manifold. C series makes it's home on shop wall now. Turbocharging the ticket for me.
richard_d
84 f250 4x4
inline 6, turbocharged.
richard_d
84 f250 4x4
Tuning is no problem with 02 sensors installed in the collectors. Also, a little port work to open up the breathing capabilities of that 300 head seams to work magic. Cant get enough HP? Try a 240 head, bump the compression. Install larger valves. Heck, if all else fails, turbo charge it.
Bottom line, what works for some, dont work for others. Do your research, listen to people that have been there, check your budget, and then make a choice.
1977 F-100
MSD6
1977 F-100
MSD6
The following users liked this post:
Originally Posted by richard
Tried offenhauser c series intake. Looks better than it works. . . . Fuel seems to condense inside those nice long runners,and rear cylinders burn too rich as the fuel runs downhill inside the intake manifold. C series makes it's home on shop wall now. .
Only reason I'm adding this is that I've seen about three hundred of these manifold discussions, and some newbie is liable to come here to find out about it.
richard, if you are still watching I'll trade you your Offy wall art for some of my own. I've got everything from 4' x 8' banners to high tech carbon fibre bike frames.
richard_d
84 f250 4x4
richard_d
84 f250 4x4
CarpetusMaximus313
32
09-24-2016 11:21 PM
freedomrock79
04-08-2016 05:35 PM
