EDELBROCK FORD 300 INTAKE - Ford Truck Enthusiasts Forums
Old 05-02-2001, 12:40 AM
rpspwp rpspwp is offline
rpspwp is starting off with a positive reputation.
I saw one on ebay a while ago. I didn't know they made one with all the stock stuff on them. At least they used to but not anymore. Does anyone have any experience with them? Are they a waste of time with the one barrel carb? Just curious. It is sort of interesting since it looks smog legal and I'm in CA. I figured with some smog headers and a new ignition, I might be able to see some gains in power.
'84 F150
YFA F/B
SROD
"Ex" => Bone Stock
Old 05-02-2001, 06:09 AM
MSTRAWN MSTRAWN is offline
MSTRAWN is starting off with a positive reputation.
Dont know about the edelbrock, but offenhauser C series bolts right up to the stock exhaust manifold. Tried the one barrell(with an adapter plate that I made) but did not notice any difference in power. Switched to the 500cfm edelbrock carb and with header installed it made a big difference, but, no smog checks for 25 year old trucks in Oklahoma. I have heard that 390 or 450 hollies tune well with the 300cid engine.
1977 F-100
300 I-6 / C-4 (soon to be AOD)
Offy intake w/Edelbrock 500CFM
Hooker Ceramic coated headers w/duals
MSD6
Whiter whites/Brighter brights
Old 05-02-2001, 10:58 AM
paulg paulg is offline
paulg is starting off with a positive reputation.
rpspwp:
Before you do any modifications to your truck's engine, make sure you can modify it. Check with state laws first. California isn't very friendly from what I have heard when it comes to dealing with people modifying there vehicles.
1994 Ford F150
300-6
Highly Modified and more to come!
Old 05-03-2001, 12:07 AM
richard_d richard_d is offline
richard_d is starting off with a positive reputation.
Tried offenhauser c series intake. Looks better than it works. Some performance gain, especially with a 4 barrel, but tuning will be a problem. Fuel seems to condense inside those nice long runners,and rear cylinders burn too rich as the fuel runs downhill inside the intake manifold. C series makes it's home on shop wall now. Turbocharging the ticket for me.
richard_d
84 f250 4x4
inline 6, turbocharged.
Old 05-04-2001, 12:56 AM
Tuning is no problem with 02 sensors installed in the collectors. Also, a little port work to open up the breathing capabilities of that 300 head seams to work magic. Cant get enough HP? Try a 240 head, bump the compression. Install larger valves. Heck, if all else fails, turbo charge it.
Bottom line, what works for some, dont work for others. Do your research, listen to people that have been there, check your budget, and then make a choice.
1977 F-100
MSD6
Old 05-04-2001, 11:54 AM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
Old 12-04-2015, 01:55 PM
Djlink Djlink is offline
Djlink is starting off with a positive reputation.
Before 76 and there is no smog check so there is no inspection.
Old 12-04-2015, 08:32 PM
The Frenchtown Flyer's Avatar
The Frenchtown Flyer The Frenchtown Flyer is offline
The Frenchtown Flyer is starting off with a positive reputation.
The Edelbrock intake was designed during the Arab oil embargo fuel crisis in the 70s to improve fuel economy. It will not gain you much if any performance, but it looks like a more efficient intake than the stock Ford log intake.
Old 12-04-2015, 09:35 PM
fordman75 fordman75 is offline
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
DJlink You do know the last post on this thread was back in 2001.
Old 12-04-2015, 09:59 PM
I didn't notice the date either. Sometimes its good to re-plow old ground on topics discussed years ago - especially if newer members do a search and still have lingering questions.
Old 12-06-2015, 05:37 PM
jack orchard jack orchard is offline
jack orchard is starting off with a positive reputation.
Quote:
I agree.,...jack
Old 12-07-2015, 01:04 AM
seattle smitty seattle smitty is offline
seattle smitty is starting off with a positive reputation.
Quote:
Originally Posted by richard
Tried offenhauser c series intake. Looks better than it works. . . . Fuel seems to condense inside those nice long runners,and rear cylinders burn too rich as the fuel runs downhill inside the intake manifold. C series makes it's home on shop wall now. .
Sounds like his manifold needed some heat. If somebody runs into a similar problem, maybe the answer would be to weld some aluminum tube to the underside of it, cap the ends of the tube, and plumb it to engine coolant. Before welding, preheat the manifold and tubing to 175-200F, and have the welder use the usual welder-tricks to minimize distortion. Since this isn't structural, the job might be done with that aluminum "brazing" rod they use to weld beer cans together at swap meets where they sell the stuff.
Only reason I'm adding this is that I've seen about three hundred of these manifold discussions, and some newbie is liable to come here to find out about it.
Old 12-07-2015, 11:11 AM
Quote:
richard_d
84 f250 4x4
richard, if you are still watching I'll trade you your Offy wall art for some of my own. I've got everything from 4' x 8' banners to high tech carbon fibre bike frames.
smog help 1979 F350 with 460. freedomrock79 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-08-2016 06:35 PM
Tuners and smogging JoshGriffith 1999 to 2016 Super Duty 17 02-22-2016 09:20 AM
diesel friendly smog shop in Orange County CA?? mototrig 1999 - 2003 7.3L Power Stroke Diesel 4 08-28-2014 03:08 PM
Friendly SMOG station in San Diego,CA? Lushman 1999 - 2003 7.3L Power Stroke Diesel 30 09-19-2011 08:32 PM
1976 460 Smog??? gt40racing 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-26-2010 07:49 AM
Tags
1994, 300, barrel, edelbrock, f150, ford, header, hooker, i6, inline, intake, intake300, manifold, modifications, paulg, series
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
