Horn stopped working. I replaced Horn relay, and just get clicks. I replaced the two OEM horns with two aftermarket horns from Auto Zone. Still do not get any sound. The two new horns come with a mounting bracket that attaches to the chassis. I assume this is the ground. I also have two wires coming in to the horn. Each horn got one wire and then I attached a crossover. Still no sound. Fuses are OK. Anybody have any suggestions?
Are you getting voltage to the horns? You need to post before buying things and
wasting money that's why we are here!! Grab your multimeter and see if you are
getting voltage right at the horns( have someone hit the button) Then we will go
from there.
