Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-12-2007, 10:42 PM
429scjgt is starting off with a positive reputation.
5.4 missing under load
my 2000 F250 w/5sp has a miss under load.It happends after it warms up, if set over night and miss the rest of the day.This just started all of a sudden!!! On level road it runs ok but will miss with the smallest of hills are even taking off from a stop!!! I have changed the plug boots a few times and went thru them last weekend ,found nothing bad there but replaced two of them..Where should i look next ?????
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-13-2007, 04:14 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Sounds like you have a coil failing. It will be hard to pinpoint which one without live data logging.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 12-13-2007, 07:37 AM
projectSHO89 has a good reputation on FTE.projectSHO89 has a good reputation on FTE.
See if you can induce the failure, then really hammer on it until you get the CEL to come on. The stored fault code should then tell you which cylinder(s) is (are) at fault.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #4 (permalink)
Old 12-13-2007, 08:35 AM
The CEL is that the check engine lighton dash?? So for no light has come on,but i will (stand on it today and see if i can make it come on). Thanks for the help
  #5 (permalink)
Old 12-13-2007, 09:43 AM
Toyman's Avatar
Toyman is gaining momentum as a positive member of FTE.Toyman is gaining momentum as a positive member of FTE.
Did you recently wash the engine, or go through a really deep water hole. I ask this because I steam cleaned my engine compartment a week or so ago and after mine ran the same way. It took about 5 days before it was back to normal. I cleaned my enigne off to pin point an oil leak, if you were wondering.
Toyman
__________________
2003 Explorer RIP frickin deer
1999 F250 4X4
2000 F650
member: FTE ORDER of Blue Max
  #6 (permalink)
Old 12-13-2007, 05:11 PM
Have not washed are ran thru water.Have tried to get the CEL tocome on today an can't get it to.If it was a coil what would be a good way to check one????
  #7 (permalink)
Old 12-13-2007, 07:11 PM
pony is starting off with a positive reputation.
I have an 02 F250 with a 5.4 and 6 spd. and it developed a miss under load...more a stumble that was inconsistant. The truck sits a lot so I thought maybe it could be water/condensation build up in the gas tank. I dumped in some gas line antifreeze (to absorb the water) but it didn't seem to help. I then cleaned the throttle body with spray cleaner..it was filthy (58,000 km. Canadian). Ran nicer but still had the stumble. Eventually I used the tank of gas and was ready to take it in to the "shop" if it still persisted after a new tank of gas and some fuel injector cleaner. Since the new gas it's been running "smooth as silk" I think I just picked up a bad tank on my last out of town fishing trip...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
