Can't find 460 Timing Cover
I have been trying to replace a 460 timing cover for months now with no luck. The markings on it say DIJE-8059 AA, it is cast iron and fits on an OMC 460 marine engine. Does anyone know what engine this part came from? All the replacement 460 timing covers I found are indented on the front where the water pump mounts but mine is flat. any help would be great!
the only cast iron one used in fords was the 79 and later medium duty trucks like the F700s and those were on 370s and 429 industrial truck engines.
Your casting number is a 71 revision and is totally different.
You might TRY a ford dealer but yeah it was probably made by ford for OMC so most likely scenerio is to find a marine outlet that handles them.
Edit, sent you a email with the name of a man that might be able to help you on this though as he is really sharp on marine use 460s, mainly jet boat stuff but he is the only one I can think of off the top of my head.
Your not going to believe this but I just went out to the garage and put my hand right on it. Same cast numbers as yours. Has been dipped and painted ford blue(por-15 engine paint) and has a new front seal installed. Cant believe I've kept it for 5 years sitting around. Must have been cause it was painted
P.S. Put some pics in my gallery of timing cover.
Dr. Driveway
11-14-2015 07:56 AM
Crewcabber
05-30-2015 05:53 PM
SoCalAngler
48
08-22-2014 01:57 AM
bluegoose95401
07-27-2012 02:53 PM
synergy141
20
11-18-2010 12:09 PM
