der... I'm stupid... Went to put the ohm meter on it and got nothing. Then started looking at the wire... well lookie there, theres a huge frey on the wire right behind the plug...what a tard! Clipped it and then put the meter on it again and was getting 14.9. Should be good, right? I love it when things are easy!!
There Is A Housing Above My Filter That It Goes Into. I Dont Know If It Is A Cooler Or Not. It Looks All Factory To Me. Does It Cost Alot On The Electric Bill To Run These.
Most of us run them on a timer for 2-3 hours,,, Less smoke at startup....(In the house garage).....
Do They Have A Timer Built In To Them Or Do You Have To Put A Timer On Them.
I have a fairly heavy duty timer , same as we use for a small electric water heater in our kitchen for coffee,,, Then an extention cord, plugged into the truck..
Where did you all get a good timer from? Gotta get one for the father inlaws truck....he plugs it in around 8pm and leaves it plugged in till around 8am the next morning.....needless to say, thats why the electric bill is very high
Thanks
Rich
