ford f-150 88 tack
Old 12-12-2007, 11:07 AM
JaysRanger's Avatar
JaysRanger
JaysRanger is offline
Cool ford f-150 88 tack
i was wanted to know how to hook up an after market tack in a 1988 ford f-150 and thsi htack has a red white black and green wire so i could use some help
Old 12-12-2007, 01:05 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
TACH ...short for Tachometer
Red to power
Either white or green to RPM signal on coil
Either whie or green to Tach Light
Black to Ground
Old 12-12-2007, 01:59 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
What brand is it? I am going to guess and say the black is ground, the red is power, the white is the lightbulb for the dial, and the green goes to the negative terminal of the coil for the signal. If you have a small battery charger, you can hook it up to that and test it out. If you get the power worked out, take the green wire and brush it against the + or the - lead of the charger, and the needle should flicker up.
wendal
11-04-2014 09:56 AM
genevanvoorst
08-26-2014 05:56 AM
genevanvoorst
03-01-2014 10:23 AM
Ford150/428/dud
Offroad & 4x4
15
02-07-2008 08:04 PM
theguy_88
1999 to 2016 Super Duty
11-27-2007 08:27 PM
Quick Reply: ford f-150 88 tack
