No power to radio! - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
No power to radio!
Old 12-12-2007, 01:30 AM
fordjockey fordjockey is offline
fordjockey is starting off with a positive reputation.
Unhappy No power to radio!
I recently installed a remote starter in my wifes 01 escape. The radio quit two days later, so i pulled out a wiring diagram and i have constant power (Memory) but no power for fused ignition. The 5 amp fuse Yellow/black wire. fuse is good. tested for continuity from radio plug in to fuse box was good. where do I go from there? any help would be appreciated. P.S. I was afraid It was something I did while installing the remote starter, but it works perfectly I also disconnected it and checked but no change.
Old 12-12-2007, 06:59 AM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Nitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant future
Did you check that the radio is grounded? Also check to see if maybe one of the plug connections has a loose wire. Check to see if the wire going into the radio is actually hot - do this by piercing the wire. This way you can tell if the radio is actually getting power.
Then there is also the possibility that the radio got fried.
Hopefully something minor though.
Old 12-12-2007, 05:32 PM
dbroad dbroad is offline
dbroad is starting off with a positive reputation.
oops posted twice
Old 12-12-2007, 05:42 PM
I also have a similar problem on my 02 Tribute , my battery went dead out of the blue . When I hooked up the jumper cables I stupidly connected backwards for a split second ( sparks ).Now my radio is dead , dome lights dont work , door locks dont work with the key off and remotes dont work at all .Everything else is ok .All the fuses are good.....can anyone help ? dave
Old 12-13-2007, 11:31 AM
dbroad, Fixed my problem broken wire to accesory relay! I Looked at the Chilton wiring diagram and from what I see The only common Thing all of Your electrical Gremlins share is the GEM generic electronic module except for the radio, But the Tribute has a microprocessor for the radio that is tied to the GEM. It may be possible the reverse voltage damaged Your GEM but I wouldnt Jump to any drastic conclusions. Go buy Yourself a Chiltons repair manual for Your vehicle. They have wiring diagrams, not the most specific but better than going in blind. Be sure to use a computer safe test light when doing Your diagnostic tests. Good Luck also Thanks to all for the advice and ideas its good to have a place to get help!
Old 12-13-2007, 02:31 PM
sfcwoodret sfcwoodret is offline
sfcwoodret is starting off with a positive reputation.
Glad to hear.
Old 12-15-2007, 12:29 PM
fordjockey...thanks for the tips , glad you fixed your problem ,I will check out the GEM .....dbroad
Old 01-02-2011, 03:41 PM
Butch91 Butch91 is offline
Butch91 is starting off with a positive reputation.
Hey guys, having the same issue... Alternator went out on my 2002 Escape 4 cylinder 4wd, and after replacing it the radio and interior dome lights won't come on... Also, same as described by the OP, the power locks only work when the key is in the ON position.
I'll look for this "GEM" and see if it looks bad... Is it something that can be purchased at Advance Auto or AutoZone, or is this going to be a dealership part? Is it fixable?
Any help is appreciated!!! Thanks!
Old 01-02-2011, 08:03 PM
96ford13 96ford13 is offline
96ford13 is starting off with a positive reputation.
dealership will fix it under warrenty
sorry warranty
Old 01-03-2011, 09:21 AM
Really? Why would they cover this fix? What exactly is it that happens?
Old 07-25-2012, 01:37 PM
Escape # 1 Escape # 1 is offline
Escape # 1 is starting off with a positive reputation.
Ignition Wire Bundle
Where can I get a wiring diagram for the 01 escape.
Like a jerk, when I got out of the Escape, my foot ripped the ignition harness that was hanging a bit too far down. Notining broken, just pulled all five wires out of the plastic harness, don't know which slots to put them back in.
This appears to be a dead end harness....just wires into a plastic loop, no downstream wires....so I have no way to match up red to red, green to green etc.
thanx
Dan with big feet.
Aftermarket radio...dead, suggestions?? agsmv1 Excursion - King of SUVs 23 05-04-2015 08:09 PM
inline radio fuses ckleine 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 10-09-2014 02:27 PM
Fuse 45??? run6.0run 6.0L Power Stroke Diesel 8 12-17-2013 05:26 PM
No power at the ignition 93turbo7.3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 11-08-2011 08:34 PM
Remote Wire location help biggmoney Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 12-29-2004 11:02 PM
Tags
escape, ford, mountaineer, power, radio, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
