Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-12-2007, 01:21 AM
buffalobob is starting off with a positive reputation.
where can I find a 1 " fan spacer for 460
Im trying to find a 1" fan spacer for my 460 clutch fan .....I installed a belt drive hydraulic pump and the std fan is just nipping the hydro pump shaft bolt
I would have thought that any speed shop would have this - not so....the 3/4 inch pilot hole and nub is the spoiler here - GM cars have 5/8 pilot and that all the mfgrs like Mr G and Hayden have ----I like this ford - but this along with a hundred other small dramas encountered in rebuilding this truck ---and the expense of anything ford makes one wonder WHY ?
are ford clutch fans fom all size v-8s interchangeable? ......and are there different length clutches ?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-12-2007, 06:23 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
C9AZ-8546-A .. Fan Spacer - 1 1/4" long - used on 429/460's: 1969/91.
D0SZ-8546-A .. Fan Spacer - 1 13/16" long - used on 429/460's: 1970/91.
Parts catalogs state: Fan spacer = pulley to fan.
There were 9 different 460 fan clutches used from 1980/91 on 460's. The parts catalog doesn't state the length.
I have no parts catalogs after 1991, but you could call FTE sponsor Green Sales in Cincinnati Ohio and ask them what was used after 1991. If it will work for you, Green has the C9AZ-8546-A spacer, but not the other one I listed. 800-543-4959. Green sells obsolete Ford parts.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #3 (permalink)
Old 12-12-2007, 06:25 AM
ford390gashog's Avatar
ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.
Summit racing sells the spacers you want. Flex a lite has them donwn to 1'' and i am using them with the stock clutch fan.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
