300 inline-6 firing order???? - Ford Truck Enthusiasts Forums
Old 06-02-2001, 01:52 PM
brodie brodie is offline
brodie is starting off with a positive reputation.
I cannot find the firing order for my 84 ford bronco 4x4. I rescently changed the cam/lifters, put an offenhuaser intake and holley 4160 carb on her. I got every thing together except the the dist and plug wires. I can't find anything anywhere and then I found this site. Thank-god.
Also, if anyone could give me a wiring diagram or tell me how to wire together the stock dist/coil/ignition system. Appearantly there are 20 or so wires hanging around in there that I don't need or have any idea what they go to. Remember that I changed my intake and carb. I no longer have all of that emissions stuff to worry about.
Other things Ive done to the ole girl: Z-gate shifter, fuel cell, 2800 stall conv, 9" rear-end, 7" of ttl lift, 38.5 supper swamper boggers, pace setter headers, tranny cooler, and I have a mallory dist and Hi-Fire ignition for later, but first I gotta get her running.
Old 06-02-2001, 10:42 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
Can't help you with the wiring, but I do know the firing order:
1-5-3-6-2-4.
Old 06-11-2001, 10:34 AM
Motorcraftsman Motorcraftsman is offline
Motorcraftsman is starting off with a positive reputation.
[font size="1" color="#FF0000"]LAST EDITED ON 11-Jun-01 AT 10:37 AM (EST)[/font][p]i know them numbers by heart 153624 clockwise rotation.
alsoyou said you had twenty or so wires on that ignition system, well im assuming its the tfi system, is it?
if i was you id switch to a simple system such as points, or duraspark 2, clifford has malory distributors for the 300 as well.
John M Floyd
Old 06-12-2001, 11:48 PM
got the mallory hi-fire IV and mallory dist. Thanks for the info and I've got her all wired up and running. Just got to tune her and start racing.
Old 06-13-2001, 12:01 AM
Old 03-24-2008, 08:56 PM
diolade2002 diolade2002 is offline
diolade2002 is starting off with a positive reputation.
i need the firing order for an 81 ford 100 pickup. inline 6. the 300.
where should i start on the distributor cap. . any info would be be greatly appreciated.
thanks man
Old 03-24-2008, 10:47 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Welcome to the site. If you scroll up you will see someone has posted it, it is:
1 5 3 6 2 4
Rotor turns clockwise. To find your number 1, there should be a "1" marked on the cap. If not, just trace where #1 is on the old cap before you take any of the old wires off.
Old 12-03-2012, 10:48 AM
Ryan12 Ryan12 is offline
Ryan12 is starting off with a positive reputation.
Are ford and GM the same as to the location of the number 1 cylinder??
Old 12-03-2012, 12:37 PM
JohnSmith3524's Avatar
JohnSmith3524 JohnSmith3524 is offline
JohnSmith3524 is gaining momentum as a positive member of FTE.JohnSmith3524 is gaining momentum as a positive member of FTE.
Don't 4 get
Quote:
1 5 3 6 2 4
unless you remove the distributor..replacing the OLD #1 in the same position on the new cap is what u must do irregardless of where the "1" is stamped on the cap.
Old 12-03-2012, 12:51 PM
Quote:
My question is concerning the location of the #1 cylinder on a ford engine compared to GM engine. Not the location of the #1 cylinder on the distributor cap.
Old 12-03-2012, 01:21 PM
fmc400's Avatar
MSEE
I don't understand what you're trying to say; your sentence is constructed in such a way that makes it difficult to read. My previous post is almost five years old; it is by chance I noticed that you were responding to it. The thread itself is over 11 years old.
Quote:
I don't know, you're asking questions about a GM motor on a Ford site.
Old 12-03-2012, 02:13 PM
Harte3 Harte3 is online now
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
Well, on any inline engine the #1 cylinder is the first one in the front.
Old 12-03-2012, 02:41 PM
my bad..
My bad, in the future I'll read and pay careful attn to the whole thread b4 chiming in..especially the date..y'all have a grate day
Old 12-03-2012, 07:03 PM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
I believe every inline 6 is 153624. I know all of mine, even my IH Scout diesel, had the same order. Oldest was a 48 Chrysler Spitfire flathead and newest my 95 300 with a bunch of Chevys, Fords, Mopars, and AMCs in between.
The old mechanics saying was 15 is too young, 36 too old, and 24 is just right.
regards
rikard
Old 12-04-2012, 03:22 PM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
regards
rikard
As has been said before, it all depends on your point of reference!
MSD failure ? grinnergetter 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-22-2014 09:45 PM
Here is a weird one... Beedub109r 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-14-2014 11:22 AM
351 Windsor Starting/Firing Issues Benefiel 1987 - 1996 F150 & Larger F-Series Trucks 4 05-15-2014 09:52 AM
Carb Backfire on Startup jbancroft 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-20-2014 10:13 AM
I6 gm hei switch no fire I6powerstroke Ford Inline Six, 200, 250, 4.9L / 300 8 02-03-2006 08:38 PM
Tags
1966, 1978, 300, 85, cid, cylinder, distributorcap, firing, firingorder, ford, id, inline, inline6, motor, order
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
