Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-11-2007, 12:26 PM
stumpbuster's Avatar
stumpbuster is starting off with a positive reputation.
heater works "sometimes"
since it started to get cold over here, i noticed when i start my truck in the morning to warm it up, the heater kicks on only about half the time.
when the heat does not turn on, i have to shut the truck off, and fire it back up again for the heat to kick on, sometimes it takes a few tries.
seems wierd to me, but maybe not to you guys hopefully.
any ideas
__________________
2005 F-250 XLT 5.4 4X4
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-12-2007, 12:41 PM
Ed Ed is offline
Ed is gaining momentum as a positive member of FTE.
Sounds like a problem I had a long time ago. Replace the blower switch to your heater. That cured my dilemmma, in fact with the new switch, the low speed blew heat better than the old switch did at high speed!
The cutting in and out I hated, someone told me that the contacts can get corroded too. However, the work involved in removing the switch to check or clean the switch contacts, I would just rather replace the switch.
I purchased my new heater switch at NAPA, and it was around $11 at the time, if I remember.
Good luck. Might be time to flush your cooling system as well, if you have not done this recently.
  #3 (permalink)
Old 12-12-2007, 01:09 PM
thanks ed!
ill try the new switch and the flush.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
