Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-11-2007, 12:23 PM
Woodyp's Avatar
Woodyp is starting off with a positive reputation.
what can I use as a direct repalcement for a 360
My daughter was driving my oil leaking 71 f100 truck (that my friends called the Exxon Valdez) and ran it out of oil and cooked my 360. I want to buy a motor from the junk yard and do a quick easy drop it in to get me throufh the winter so I can finish the EFI upgrade that I am working toward.
My question is what are my enginge year and size options for a direct drop in that will work with my tranny, motor mounts and ect...
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-11-2007, 12:44 PM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
either another 360 or a 390.
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #3 (permalink)
Old 12-12-2007, 08:17 AM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
I agree, 360 or 390 would bolt right in. Just keep an eye on the flywheels and clutch plates, the 390 might be a bigger clutch. You can just use the 360 flywheel in that case.
Otherwise, a 410 or 428 might bolt in if they have the right exhaust manifold bolt pattern. Just be sure to use the 410/428 flywheel.
As for what years, all years of 360, and later 390 - there might be a motor mount issue with the pre-65 or so, I believe.
Might want to ask in the FE forum.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Volant CAI, eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #4 (permalink)
Old 12-12-2007, 09:31 AM
Woodyp's Avatar
thanks for the info that's what I suspected. And, I'll post in the FE forum, funny, I never noticed that forum before.
  #5 (permalink)
Old 01-30-2008, 05:26 PM
lrd56 is starting off with a positive reputation.
330-391 bolt up
you can also put in a 330-361-391 .you can find them in bseries busses.also big f series trucks .they have a govener that you can set for what max rpm you want.they eat gas but have lots of low end torque.doug herbert has mechanil fuel injection.that works good.no computer.the fuel injection is called the flying toilet bowl.
  #6 (permalink)
Old 01-30-2008, 06:10 PM
krewat's Avatar
Quote:
Those are FT engines. They are externally balanced so the flywheel is different.
They also have motor mounts on the cast-iron timing cover, NOT the engine block. With the FT crank snout being larger, the timing cover from the FE will not fit (unless it's certain 330's). The exhaust manifolds are also different.
Stick with an FE. An FT engine would slow you down in terms of HP. They are torque monsters.
Not impossible to put an FT in there, but more work than you think upfront
__________________
  #7 (permalink)
Old 02-03-2008, 01:09 PM
*********- High Plains
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
Art is right, with the forged steel cranks in the FTs, they don't rev enough for light vehicle use, and with their lethargic compression ratio and cam profiles, they are made to haul heavy loads.
You shouldn't have any problem finding another 360 in the junkyards, a 390 is a little more difficult, but they can be found.
  #8 (permalink)
Old 02-03-2008, 01:48 PM
krewat's Avatar
And watch out, lots of "390s" out there are really 360's when you get them home
__________________
  #9 (permalink)
Old 02-03-2008, 01:50 PM
monsterbaby's Avatar
monsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant futuremonsterbaby has a brilliant future
look around you may also be able to find a 352 which will bolt in also, although you may have to use your pan and pickup tube and flywheel since most of them will be in cars.
__________________
Dying's not so bad
It's living that will kill you off
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
