Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #436 (permalink)
Old 06-07-2008, 08:51 PM
waynebo waynebo is offline
waynebo is starting off with a positive reputation.
Quote:
Originally Posted by topgunn View Post
I apoligize for stirring the POT ( I like seeing what surfaces). I am just tired of hearing all the NAY-SAYERS. IF we had listen to them over the past, we would still be walking and sending messages on rocks. I believe that keeping an open mind about any subject then more knowledge is passed around. We are all done for when we stop trying to do something because someone tells us that it won't work. Edison said he found a lot of ways NOT to make a light bulb befor he found the right way. SO everybody that trys a different approach is narrowing down the other ways until the best way is found.
i'll drink to that,your 100% right
__________________
<---i'm miss'in the same tooth..
95 f250 P.S 2wd 5spd,,,,
  #437 (permalink)
Old 06-07-2008, 09:43 PM
David85's Avatar
David85 David85 is offline
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
Well said, points to ya topgunn.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #438 (permalink)
Old 06-08-2008, 12:09 AM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE.
Quote:
Originally Posted by archangel View Post
Well, blocking off the radiator added 4 mpg on the freeway alone, and the tail gate closed in an open bed along with the mirrors are a bigger drag that you might think.
It was more than I thought.
You also have to remember, if you were to double your speed you need quadruple the power, so each MPH faster you go the bigger the mirrors become.
The wind resistance difference of the mirrors at 55 and then going 1 mph faster to 56 is not much compared to the wind resistance of the mirrors at 75 and then going 1 mph faster to 76.
After what I read recently, I'd bet if I made the same trip at no faster that 45 mph (the minimum speed for high gear to kick in) I might have gotten up to 30 mpg.
BYW guys, I almost NEVER carry anything other than a spare tire.
I hauled a trailer and a heavy duty mower last weekend and on Tuesday Grammy wants her pine tree in the back yard cut down and hauled away.
You are right about drag increasing, IIRC it increases at square of speed. If you could keep the air from going under your pickup you would probably increase your mileage as well.
FWIW we had a 95 psd (3.55's) that made 21mpg pulling a 30' 5er thru Yellowstone park cruising around 45mph all day long.
__________________
Marc
2002 F350 SRW CC LB 4X4, PSD, 6637, CCV, Pretty much Stock
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip(for now)
  #439 (permalink)
Old 06-08-2008, 05:47 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Quote:
Originally Posted by ernesteugene View Post
So depending on temperature and relative humidity, your PSD is typically ingesting about 1 to 10 GPH of water, and your theory says that ingesting an additional 0.0216 GPH of water due to the addition of a HYDRO-4000 is going to lower EGTs???
Gene:
The only thing I want to clarify here is that what I mentioned in my last post is not MY theory... just a regurgitation of the explanations I've read from others who proposed the theory related to why there are supposed to be lower EGT's when injecting HHO into the PSD intake system.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #440 (permalink)
Old 06-09-2008, 01:15 AM
tradergem tradergem is offline
tradergem is starting off with a positive reputation.
I thought that the reason for the lower EGTs was because the HHO burning in the combustion chamber caused more of the diesel to also burn inside the combustion chamber therefore releasing more heat inside the combustion chamber before exiting into the exhaust? Does incompletely burned diesel continue to burn inside the exhaust manifolds?
Jim
__________________
1990 F250 XLT 7.3L N/A E4OD 4X4 4:10 axle ratios
  #441 (permalink)
Old 06-09-2008, 02:05 AM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
I thing the effects of HHO are small but many.
A little extra fuel, a little water, a little steam clean action,.... etc
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #442 (permalink)
Old 06-10-2008, 03:02 PM
parkland's Avatar
__________________
  #443 (permalink)
Old 06-10-2008, 06:10 PM
Marianna2003 Marianna2003 is offline
Marianna2003 is starting off with a positive reputation.
Hydrogen and oxygen burn at 8000 FT/SEC. Technically thats an explosion not a burn. It's like igniting all of the fuel in the cylinder in in less than a second. By the time the exhaust valve opens, all of the fuel is consumed and only the byproducts are pushed out of the cylinder.
  #444 (permalink)
Old 06-10-2008, 06:13 PM
dustan52's Avatar
dustan52 dustan52 is offline
That's what she said!
dustan52 is starting off with a positive reputation.
Anyone using hydrogen with bio...?
__________________
Dustan
1999.5 F350 7.3 Power Stroke Crew Cab 4x4 Long bed
Zperformance 90hp 6 setting module, AFE 4" turbo back exhaust, diy 6637 filter, stancor gpr, LT275/70R18, 3 pod pillar gauges, CCV mod, euro lights, hpx
PAA Member #51 http://www.ford-trucks.com/user_gall...9/189591.80.80
  #445 (permalink)
Old 06-10-2008, 06:34 PM
USAF CCM's Avatar
USAF CCM USAF CCM is offline
USAF CCM is gaining momentum as a positive member of FTE.
Water Injection
I used to fly on the KC-135A model air refueling tanker; we used water injection when we needed to launch with heavy gross weights; older B-52 bombers did as well. At a certain point of throttle run-up the engines were injected with de-mineralized water (it all depended on outside air temperature & water temperature). You talk about diesel smoke...whoa I'm telling you day would turn into night. This lasted for just a couple minutes during the take-off sequence.
We lost some great vets when the water system failed during a critical phase of flight, i.e. loss of power, not enough airspeed plus too close to the ground.....well you get the picture. V/r Les
__________________
Les
2002 True Blue F350 Ext Cab 4x4 7.3 PSD SRW LB
Rhino Line; 4" BDS Lift; Bilstein Shocks; Centerline Rims; Racor Ext Fuel/Enviro Bypass Oil/Magnafine Trans Filters; 8 Autometer Cobalt Gauges; AIS; Toyo 315/75R16 ATs; Banks Monster Exhaust, Mag-Hytec Trans & Rear Diff Covers; BTS; ATS: AIH Delete; Spearco CAC; DP Tuning; DI SS Ups
30 Yr USAF Vet
  #446 (permalink)
Old 06-11-2008, 12:58 AM
parkland's Avatar
Thats really something.
I cant imagine what a wild ride that'd be.
__________________
  #447 (permalink)
Old 06-11-2008, 01:18 AM
parkland's Avatar
__________________
  #448 (permalink)
Old 06-11-2008, 02:59 AM
David85's Avatar
Love the B52s....solid design and still going strong after over 50 years of service. I'm a sucker for old machines that serve that well and that long.
__________________
  #449 (permalink)
Old 06-11-2008, 06:50 AM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
2008 Ford F-350
alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE.
Just a little story to illustrate how wild that ride can be:
Some time ago (actually a long time ago) I was privileged to work on the BUFF as an engine mechanic and later as an engine recovery crew chief.
Part of our function was to run engines after maintenance for checkout, and this included testing the water injection system. Our check list included three critical items....making sure the chocks were in place, setting the parking brakes, and having a firetruck on standby. (The firetruck would motor out to the flight line and park facing the aircraft some 70- 100 feet in front of the nose). Actual testing would then be to run the engines at 80% power, then hit the water switch.
All well and good. So here comes this hotshot recovery chief, (no, not me!),
who proceeds to run all 8 engines up to 80%, and hit the water. Only thing was he skipped one item in the check list- the parking brakes. When the water hit, the aircraft literally jumped the chocks, and by the time he got the water off, the throttles back, and the brakes on. the aircraft was nose to nose with the firetruck. Needless to say the fire crew had to clean the truck of what the crewchief was knee deep in.
__________________
TRITON V10 - THE BEST KEPT SECRET -
(But word is getting out).
'08 F350 Scab SRW V10 w/ 4:10
07 Gulfstream Prarie Schooner
'05 Escape
' Passed the exam today! I am now a licensed instigator!
  #450 (permalink)
Old 06-11-2008, 10:43 AM
parkland's Avatar
Hahaha!!
That sounds like great fun!
Sometimes i wish i woulda done something exciting like that....
__________________
Tags
07 , 2002 , 73 , differences , duramax , f250 , famisto8yahoocom , ford , hanger , homemade , hydrogen , kit , sale , specs , systems , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
