Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #376 (permalink)
Old 05-25-2008, 05:36 PM
twtcad's Avatar
twtcad twtcad is offline
twtcad is starting off with a positive reputation.
Well at this point I'm scrapping my rod idea unless someone else has gotten it to work or explain/fix my amperage dropping the way it does. I can only assume in my basic mind it's because of the steel I'm using. A buddy of mine has some sheet ss that I can have if I can figure out how to cut it. Then maybe in keeping with my same design stack several 16"x2" plates together in place of the rods in a similar configuration as the "smacks booster". But this is yet to be determined and done! To be continued.........
__________________
'03 Excursion Limited 4x4 7.3l - Family Hauler Performance Mods: Superchips flashpaq set to Performance, slotted/dimpled rotors, Zoodad mod, Steveracer mod; D.I.Y. intake. Interior Mods: Alpine CDA-9883 Head Unit w/ SWI-JACK & iPod, Infinity & Polk 5x7, Sirius satellite, Alpine PKG-RSE2 10.2 Drop Down DVD w/ PS2 Slim.
  #377 (permalink)
Old 05-25-2008, 10:00 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
twtcad. I'd play with your plate set up in a bucket first. Since the plates will provide more surface area in contact with the water you should need fewer plates or may require more amps.
How thick is the stainless steel? Light gauge you can cut with tin snips, if it's heavy you can buy a carbide blade for a circular saw or grinder to cut with.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #378 (permalink)
Old 05-25-2008, 10:41 PM
lookin71 lookin71 is offline
lookin71 is starting off with a positive reputation.
Seen this yet?
Hey guys,
I have been following this post for months. Recently, WAVE-3 news here ran a story on Hydro 4000.
Here is the link for the news story:
WAVE 3 TV Louisville, KY | Hydro 4000 makers say device can substantially improve fuel mileage
Here is the link for the product: www.hydro4000.com
According to the story, they went from 9 mpg to 23 mpg. However, after reading about gassers, they have a problem with the Ox Sensor adding more fuel as it senses a lean mixture. So how did they conquer this problem?
Hope this helps.
Donnie
  #379 (permalink)
Old 05-25-2008, 11:44 PM
ALEXVB22's Avatar
ALEXVB22 ALEXVB22 is offline
ALEXVB22 is starting off with a positive reputation.
EFIE devices from what I understand fixed the gas engine O2 Sensor problems...
Alex
__________________
05' F-350, Kingranch, Crew, Dually...
SCT X3
Afe XP Stage 2 Intake!
  #380 (permalink)
Old 05-26-2008, 01:30 AM
David85's Avatar
David85 David85 is offline
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
If you guys are interested, we just did some testing with two new types of generator on this thread:
http://www.ford-trucks.com/forums/72...ml#post6193725
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #381 (permalink)
Old 05-26-2008, 02:12 AM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
Quote:
What kind of rods did you use? "NORMAL" rods are steel mabye galvanized coating too, you'd need solid stainless steel rods, or plates.
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #382 (permalink)
Old 05-26-2008, 10:53 AM
twtcad's Avatar
Quote:
The rods are from Lowe's "Steel Works" Allthread-Plated 5/16"-18x3'-0" cut in half to make 18" rods w/ about 16" in the water. They are plated and I've run the unit total for about 3-4hrs (not continuous) so I would think most of the plating would have been cooked off. It should still make a good amount of gas just the rods would not last as long. Did you ever do a test on your setup of how much gas you produced in a minute?
__________________
  #383 (permalink)
Old 05-26-2008, 10:57 AM
twtcad's Avatar
Thanks.....yes it's a light gauge and he has some power snips that we are going to try.....great tips though I'm sure I'll end up using one of them!
__________________
  #384 (permalink)
Old 05-27-2008, 11:23 PM
pasotx pasotx is offline
pasotx is starting off with a positive reputation.
5 gallon bucket
I posted earlier that my generator was pulling 50+ amps and producing little gas. Have not measured the output but I dumped out half the water and draw dropped to 20 amps. Will probably popur our all the water, rinse and start with just water and add soda to bring it up to 25-30 amps. Then measuer the output. Glad to know that I did not have a short. The stainless screen is holding up nicely. I may hit it with some sand paper while dissassembled. Wish I could figure out a way to put perforated tubing in the bottom and pull a vacuume on the tank.
Has anyone tried a belt driven vac pump from a diesel?
  #385 (permalink)
Old 05-28-2008, 03:58 AM
parkland's Avatar
50 amps?!!?!?!
Stainless screen?!?!?
I missed something somewhere..... Thats awesome.....
All jokes aside, my coat hangers seemed to make decent gas with low current draw.....
__________________
  #386 (permalink)
Old 05-29-2008, 03:42 AM
archangel archangel is offline
archangel is new and has a neutral reputation at this point.
50 amps?!!?!?!
Wouldn't that be funny to find out that the alloy used to make those cheap as hell coat hangers was the best alloy to use?
There was a link I saw a few days ago (I need to find it again) about an article where someone in another country was using a unique alloy and was getting impressive amounts of Hydroxy compared to plain Stainless steel.
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
  #387 (permalink)
Old 05-29-2008, 09:47 AM
Marianna2003 Marianna2003 is offline
Marianna2003 is starting off with a positive reputation.
It sure would be good if you can find out what material other than SS they were using.
  #388 (permalink)
Old 05-29-2008, 08:21 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
I saw a post about some strange materials, that did not sound cheap as I read them.
I think that link to the strange materials was up several posts from the end of the HHO thread in the IDI forum, which was given a couple posts up in this thread.
Nickel Iron Oxide?
Here is the link to the site.
Report:Robert Pritchett's Mileage Results from Hydroxy Boost Addition - PESWiki
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #389 (permalink)
Old 05-30-2008, 02:21 AM
parkland's Avatar
I'm thinkin its like this:
Slow degrading metal, lots electricity =
Fast degrading metal, less electricity.
2c's
__________________
  #390 (permalink)
Old 05-30-2008, 12:10 PM
parkland's Avatar
check those out boys
__________________
Tags
07 , 2002 , 73 , differences , duramax , f250 , famisto8yahoocom , ford , hanger , homemade , hydrogen , kit , sale , specs , systems , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
