Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #361 (permalink)
Old 05-16-2008, 02:54 AM
gumboluvr's Avatar
gumboluvr gumboluvr is offline
gumboluvr is starting off with a positive reputation.
WOW Will that really work?
archangel,
will generic brandy work? Also, where's the choke on my truck?
Quote:
Originally Posted by archangel View Post
My reply?
Ya just fill your tank with water, add half of a 750 ml bottle of the best brandy you can find and turn your choke all the way up and your good to go.
Then hang on to the remainder of the brandy because you will need it later.
__________________
94 7.3L Factory Turbo
ATS Snail, 3" Down Pipe Upgrade
4" Stacks, with Rain Caps!!!
5 Speed Manual
Extended Cab, Long Bed
4" Air intake with AFE factory replacement high flow filter.
Autometer Pillar Mount Pyro, Boost, & Vacum Guage Phantom series.
SunPro Voltmeter, water temp, & oil pressure guages
  #362 (permalink)
Old 05-16-2008, 03:18 AM
I'M DK I'M DK is offline
I'M DK is starting off with a positive reputation.
Quote:
Originally Posted by gumboluvr View Post
archangel,
The choke control is right next to your spark plug relay switch.
DK
  #363 (permalink)
Old 05-16-2008, 03:51 AM
archangel archangel is offline
archangel is new and has a neutral reputation at this point.
Quote:
DK
And if the brandy is of a superior enough quality, you wont even need spark plugs!
Plug them holes and save even more money!
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
  #364 (permalink)
Old 05-17-2008, 12:30 AM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
If you get bacardi 151, you can eliminate the fuel filters and any sensors because the strength of the alcohol is so strong.
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #365 (permalink)
Old 05-22-2008, 09:47 PM
twtcad's Avatar
twtcad twtcad is offline
twtcad is starting off with a positive reputation.
Well I finally finished building my first creation.....and I'm saddened at the moment because it does not seem to work. I've also been posting on another similar thread but I'm not sure if you guys have read it and I would definitely like to have from Parkland on his thoughts about this.......if he has any............
After getting everything connected properly to my truck battery for testing this is what it produced............
I reconnected all the wires and wired the amp meter properly and installed a 30amp fuse inline at the battery and started playing. First I tried no baking soda and I was drawing around 10amp so I added 1tps of baking soda and the meter increased to around 15, so I added one more and my amp meter was just over the 20amp mark on a 20amp meter. Very quickly the water started to look like it does on the pic......yucky and the foam began rising slowly to the top! I was about 2-3 inches below the top when I started. Also for as many little bubble and the occasional big bubbles that were produced I didn't seem to get anything out the hose. I'm really at a loss at the moment and I'm not sure what to try next. But it really looks like my all-thread rod us busted..........any thoughts on this? Thanks and I hope it's not against any rule to have posted similar info in two different threads.
__________________
'03 Excursion Limited 4x4 7.3l - Family Hauler Performance Mods: Superchips flashpaq set to Performance, slotted/dimpled rotors, Zoodad mod, Steveracer mod; D.I.Y. intake. Interior Mods: Alpine CDA-9883 Head Unit w/ SWI-JACK & iPod, Infinity & Polk 5x7, Sirius satellite, Alpine PKG-RSE2 10.2 Drop Down DVD w/ PS2 Slim.
  #366 (permalink)
Old 05-22-2008, 10:01 PM
pasotx pasotx is offline
pasotx is starting off with a positive reputation.
Oil?
Looks like you had some oil on the bolts you used as electrodes. Can't see it being anything but contamination. How hot did the rods get?
Pasotx
  #367 (permalink)
Old 05-22-2008, 10:23 PM
parkland's Avatar
What material are the rods made of?
My water used to get like that from the coat hanger rods, but depending on the metal content, and any coating on the steel, you could end up with a nasty soup....
Run it for a couple hours on a charger or something, clean the water, then again. If the water is always crappy like that, you may need different rods.
Looks good though, no all unlike my next one is gonna be.
If the rods are coated with a protective coating, paint, or anything there will be little floaties in the water. Run the unit on a charger or something and you might "burn off" the coating crap off the rods.
Put some of that goup on a sheet of white paper and examine it, try to describe what its composed of.
__________________
  #368 (permalink)
Old 05-22-2008, 10:39 PM
twtcad's Avatar
Thank You guys.....that is incuraging! The rods are from Lowe's "Steel Works" Allthread-Plated 5/16"-18x3'-0" I wanted to try cheap rods @ less than $3.00 each that gave me my 12 - 18" pieces for less than $18.00 where that $18.00 would probably just cover 1 in 304 or 316ss. I didn't even think about oil or the coating......my charger is only rated for 8amp and the first time I connected it, it was to the charger and it pegged the meter and only ran for about 30sec before it shut itself off. I'll see if my neighbor has a larger one I can use to run for a while. Man I really hope that works.....I've been really eager to try this baby out in my truck. Just so you know, I used 3" pvc and it holds just over 1gallon of water and it fits perfectly between my grill and my radiator.....
Oh and the rods did not get hot at all.....I could touch them with no noticeable heat. (sticking out the end)
__________________
  #369 (permalink)
Old 05-22-2008, 10:40 PM
twtcad's Avatar
Hey Parkland, are you still running your original bucket setup? How is your fuel mileage been?
__________________
  #370 (permalink)
Old 05-23-2008, 06:59 PM
twtcad's Avatar
Well I got to play again this afternoon.......it has run for about an hour with no baking soda. It seems that most of the foam is gone, but the water still turns green, most likely because of the metal. I flushed it really well and as you can see in the pic, the - rods are a grey color and the + rods are a brownish color.
So then I can a couple of tests w/ a 1.89l (2 quart) plastic bottle full of water upside down with the tube in it to see how fast it displaced the water. With 1tsp of bs it took 15min running @ 15amps. With 2tsp of bs it took 10min to fill running @ 20amps. Not as good of results as I was hoping but I was also using regular tap water as I went through 3gal of Culligan water the other day. I'm going to try again Sat or Sun the same test w/ our bottled water from Culligan. Hopefully I'll get better results. How much was it again a minute we need to make improvements in fuel mileage? I do not think I'm even close...............
__________________
  #371 (permalink)
Old 05-23-2008, 07:10 PM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE.
Glad to see some pics!! Where are you going to mount that??
__________________
Marc
2002 F350 SRW CC LB 4X4, PSD, 6637, CCV, Pretty much Stock
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip(for now)
  #372 (permalink)
Old 05-23-2008, 07:19 PM
twtcad's Avatar
If you remove the grill, there is a ton of room right in front of the radiator. The bottom section will be right about the bumper level and the top will be just below the trim piece at the top of the grill. I'm hoping that will also help keep it cool. Once I get the gas production up to speed, I will mount it and post some more pics........
__________________
  #373 (permalink)
Old 05-25-2008, 02:17 PM
twtcad's Avatar
A couple of us in this thread are making different units....could some of you guys who have played with this take a look here too? It would be nice to combine these threads, but I think it would be too hard, they both are pretty big. But rather than post everything in both threads maybe we/you could watch both and follow along as I do. There are very knowledgeable minds in both thread, it just would be nice to combine them.......just my 2 cents!
__________________
  #374 (permalink)
Old 05-25-2008, 04:31 PM
parkland's Avatar
Looking good, remember, you'r not supposed to need a whack of gas, all it takes is apparently very little, around 10 amps of draw should be around the mark.
The big tractor trailer rigs hydrogen systems apparently use 20-30 amps ***apparently***, so 10 sounds right to me for a small truck.
(Who knows? :/ )
Not using my bucket, toast quite a while ago, new system in the works (Actually the generator looks similar to twtcad's, exept mine has a small finned cooler, and the gas bubbles travel in a liquid stream to a resevoir under the hood. Also, looks like my generator is a little bigger( about 4 ft long, 8 rods) Also my rods are internally supported and stick out of 1 end, so you can un-screw the entire assembly.
Generator is going under truck, and a water pump will circulate the gassy water through the cooler and into the resevoir which will also be linked to the air intake.
You cant notice a different running sound, but if you inject a large amount of gas, you can make the truck sound like a sled puller. If you have a large resevoir of hydrogen, and you meter it nicely to the intake, and give WOT, the engine really kicks out some HP!!!
I wont do it anymore, because of the scary 1-2 shift. (Tranny does NOT like the power i think...)
The boost guage jumps so fast that we originally suspected a manifold explosion. Will pin the boost guage needle againt the stop pin, and burn rubber.
__________________
  #375 (permalink)
Old 05-25-2008, 05:01 PM
twtcad's Avatar
Parkland.....did you ever measure your rate of gas, 1 liter per minute or what ever it was? Have you tested your rod setup yet and are you using ss rods? My last test started at 13amps and dropped to 5amps very quickly. The only thing I can assume with the fast amperage drop is the rods are too corroded.......
__________________
Tags
07 , 2002 , 73 , differences , duramax , f250 , famisto8yahoocom , ford , hanger , homemade , hydrogen , kit , sale , specs , systems , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
