Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #241 (permalink)
Old 01-31-2008, 11:09 AM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
2008 Ford F-350
alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE.
Quote:
Originally Posted by F250_
This concept has been being used as a "gadget" on non-diesel cars and trucks for some time. It works... simple as that.
I seem to be gaining ground on my goals for electronics control of voltage (read as hydrogen production). It seems that what I am needing as part of my scheme is the use of a transistor circuit or two, or three. Now to just figure out how to configure the total circuitry package and see how much it would cost to build the thing and test it.
If you can define it I can build it.......you need to decide 1) what you want to control, 2) How many control lines are needed (outputs), and 3) What the inputs are.
Each of the above need to be broken down into input or output, voltage, current, and time parameters. Given that, I can build & bench test.
__________________
TRITON V10 - THE BEST KEPT SECRET -
(But word is getting out).
'08 F350 Scab SRW V10 w/ 4:10
07 Gulfstream Prarie Schooner
'05 Escape
' Passed the exam today! I am now a licensed instigator!
  #242 (permalink)
Old 01-31-2008, 11:29 AM
mprice mprice is offline
mprice is starting off with a positive reputation.
From the chemistry involved you really need to be measuring amps, instead. You are adding electrons at one side and taking them out of the other. For every 2 electrons you get 2 Hydrogen atoms and 1 Oxygen. Amps is roughly a measure of how many electrons per second are passing down the wire. Volts is roughly how hard you are pushing on the electrons.
Calvin
  #243 (permalink)
Old 01-31-2008, 12:09 PM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Quote:
Calvin
Calvin:
I understand exactly what you're saying, but I would clarify it just a little bit with this. You're correct in that it is the variance of amperage that will control the gas ouput rate. However, in order to control that amperage output, the "input" will probably be something like milliamps or volts that will be the output from an onboard sensor (i.e. boost gauge, tach, throttle position sensor, fuel flow, etc.). The variance in this "input" to the "controller" is what will determine how to control the amp output to the generator.
At least, that's the concept I have running around in my non-electronically based thinking process.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #244 (permalink)
Old 01-31-2008, 12:40 PM
Calvin:
I wasn't so much responding to you as to the post before yours; sorry to quote yours instead. If someone just wants a guage to show relative gas production he'll need an ammeter and not a voltmeter.
I assumed you would be sending a PWM signal into a SSR from a uC relative to air flow. The operator controlled value would be a fixed H/Air ratio. You would need to periodically sample the gas generator's resistance and use that to apply the correct voltage to give the required current. If my Chem101 wasn't so rusty I might be able to give a good gas volume/amps ratio.
Summary:
Sample rpm
Sample gas generator resistance
Sample ambient temp
Read desired H ratio
RPM * displacement = intake volume/minute
Intake volume * temp correction * g/ltr for air = intake mass
intake mass * H ratio setting = H mass needed
H mass needed * amps correction = amps needed
amps needed * generator resistance = volts needed
Output/Adjust PWM signal to SSR to get the right Voltage
I'm thinking maybe a potentiometer and ammeter would be easier.
Calvin
  #245 (permalink)
Old 01-31-2008, 01:24 PM
alchymist's Avatar
"Mifflin Clay"
2008 Ford F-350
Summary:
Sample rpm
Sample ambient temp
Calvin
Since you guys seem to have this well in hand, I guess I'll just bow out.........
Just one more comment - why sample "generator resistance? Assuming the thing is running and you're controlling it, you already know the resistance - you know the voltage applied and the current drawn at any given instant..........why make the job harder than it is????
__________________
'05 Escape
  #246 (permalink)
Old 01-31-2008, 01:39 PM
I've always considered it easier to build something to output a given voltage versus a given current when high power is needed. It's also a lot easier to sense voltage than current. No doubt there's more than one way to do it.
Calvin
  #247 (permalink)
Old 01-31-2008, 02:29 PM
F250_'s Avatar
2002 Ford F-250
Don't leave, now, alchymist... your input is not just welcome, but needed. In this arena, I'm full of ideas without practical electronics knowledge to turn them into something meaningful. In fact, I'm just now wondering if it might be simpler to use the air velocity in the intake tube and control to the engine's natural air flow demand that is generated by the turbo... controlling an H:air volume ratio, essentially.
I know that amient temperatures, humidity, and barometric pressure make the volumetric flow not nearly as exact as a "mass" air flow, but since virtually all of the "commerically available" generators are controlling to nothing - just outputting gas on a steady basis - this volumetric flow ratio would be an improvement over their systems and, perhaps easier than what we've talked about thus far??
What do you guys think? Fire away.
__________________
  #248 (permalink)
Old 01-31-2008, 04:58 PM
TraderJ TraderJ is offline
TraderJ is starting off with a positive reputation.
Guys,
I know a good bit about hydrogen production and IC motors.
All this is not as easy as parkland says...and the mileage is not going to boost to a 5 mpg gain.
All I will say is if you are truley interested in learning more about hydrogen production
and running mixes in IC motors you need to read and study ALOT!
This is not a new concept ...There are real dangers and a handful of you are about to ruin a $6000 motor for 1-2mpg if you get it to work.
There are bubblers for safety to keep you from ummm...dying
Depending on your plate config. your voltage and amp values are going to change.
There is a miilion variables and it is not as easy as wire hangers baking soda and water.
(btw ...the more baking soda does not increase hydrogen production..it is simply a better solution for hydro)
Please go to this website and seach the forums on hydro production and diesels and/or gassers (same thing) This will start to help you understand what is involved. They don't sell anything...they are just like us here...trying to help the next guy.
WWW.OUPOWER.COM (these guys live for this stuff and are a hell of alot smarter than most of us on the subject)
I am not being negative...It can and will work...but in diesels without mods you will completely destroy you motor.
One thing to keep in mind ...hydro burned in the head=WATER...more than you think...not good for our diesels.
Most test moters running straight or mixes are shot in a shot period of time.
Great thread though...and def keep reading and learning about hydro...it will be the way in the future
Check that site out...go to the forums...you will be up all night!
Very cool stuff!
  #249 (permalink)
Old 01-31-2008, 05:04 PM
David85's Avatar
David85 David85 is online now
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
Why would a small amount of water in the head be a bad thing?
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #250 (permalink)
Old 01-31-2008, 05:40 PM
The water introduced is the least of the problems...It probably would be fine for awhile.
All I ways trying to say is read...read...read...Look on utube, there are tons or electrolizer designs and different ways to build a hydro booster. Lots of people including myself have built hydro boosters. Just be careful
Hydro ignites or I should say explodes at a extremely fast rate ...way faster than gas or diesel...that's why it is so difficult to run a car on hydro because hydro doesn't have near the energy as gas/diesel...it takes loads more hydro to power a IC motor than with gas/diesel
This is an experimental type deal, not a build it and get 25 mpg thing. trust me if it was that easy ....well you know the rest.
Look at these and keep searching ....it is possible like I said...but don't experiment if you rely on you truck to get you to work. Buy a junker and use it.
http://oupower.com/phpBB2/viewtopic.php?t=1796&highlight=diesel
http://oupower.com/phpBB2/viewtopic.php?t=1408&highlight=diesel
  #251 (permalink)
Old 02-26-2008, 10:47 PM
crosbo's Avatar
crosbo crosbo is offline
crosbo is starting off with a positive reputation.
So, don't purchase one of those "nice" systems being sold on ebay...and add it our our Strokes to increase the efficiency of our engines...and combat the overall expense of running our rigs (fuel price increases)?
__________________
__________________
Tom
'00 CC F250 4x4 Auto 4" Magnaflow, S&B Cold Air Intake, AIH, Edge A2/Juice, HPX, Pre-pump, In-Tank, CCK, 203 Thermostat, Air Horns, XM Satellite Radio, 2" lift, 315's, Trucool 4739, '06 Grill and emblem upgrades, RealTree skins and a hot babe in the passenger seat!
  #252 (permalink)
Old 02-27-2008, 06:01 AM
Chance_Thomas's Avatar
Chance_Thomas Chance_Thomas is offline
Chance_Thomas is starting off with a positive reputation.
Here is a good link.
__________________
2000 Ford F250 XLT 7.3L 4X4 Lariat, Garett GTP38R ,DP Chip, BTS VB, 6637 Filter, 55 Gal combo\tool , Tri Pod AutoMeters Gauges, 315's Bighorn Maxxis, 4" Lift ,HPX Crossover and 4" MBPR Exhaust
  #253 (permalink)
Old 02-27-2008, 09:16 AM
rmilchman rmilchman is offline
rmilchman is starting off with a positive reputation.
Quote:
Originally Posted by Chance_Thomas
Very interesting. When does the water shortage start
__________________
2002 F-350 4X4 CC PSD. straight pipe, k&n air box, tuner, 203 thermostat, mag-hytek tranny pan, tranny springs and valve, ranchhand bumper, air horns
  #254 (permalink)
Old 02-27-2008, 09:44 AM
F250_'s Avatar
2002 Ford F-250
Quote:
TraderJ, I've been considering what you've said here ever sine you first posted this information, and I am wondering why the water would be any issue at all.
When you look at the materials of construction and use in internal combustion engines, are not we using virtually the exact same materials in the combustion chambers for both gasoline and diesel engines. We all know that one byproduct of the gasoline combustion is water because we can see it dripping from tailpipes. But don't both engines use similar piston/ring materials, iron blocks, iron exhaust headers, and non-stainless exhaust systems.
Now, I know that we have a turbo that is mild steel while the gassers are typically not running a turbo... so is that the point of contention in this water issue? Or is there something else I'm missing here?
Also, can you enlighten us on more of the details regarding the "other issues" which result in engine failures for those who run a hydroboost setup? I know that I have seen one or two people suggest issues like "hydrogen embrittlement" for combustion chamber/exhaust components, but can't find any scientific data or reports to substantiate that suggestion.
Keep in mind that I am not necessarily saying you're wrong... I just want to see some research information that addresses these issues specifically.
Also, just to prevent an assumption on your part, I have spent some time (perhaps not enough) looking through the two links you provided. However, I am still left without any information supporting your post aside from seeing yet "more ways to skin the cat" in terms of hydrobooster designs.
Any good information would be greatly appreciated.
__________________
  #255 (permalink)
Old 03-04-2008, 02:15 PM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
What was the final outcome of this post. Did anyone make another generator for an occasional juice of power or a bubble melody to increase the oxygen and hydrogen in the naturally aspiration pre turbo lines?
__________________
528,500
Goldie.
Tags
07 , 2002 , 73 , differences , duramax , f250 , famisto8yahoocom , ford , hanger , homemade , hydrogen , kit , sale , specs , systems , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
