I am looking to order a 08 F250 or F350 V10 CC 4x4 and recently noticed someone mention that if you order the 4.30 gear that it comes with Dana 60 axle. What would be the advantage of of this axle over the standard one and is this axle for both the front and rear?
All SD's since 2002 got the D60 up front. If I recall...the 'Super D60' is available on the F350 Dually (as an option) and the F450-550 due to the higher GVWR. It is also wider to allow for a sharper turning radius.
