Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #151 (permalink)
Old 03-25-2008, 09:30 PM
TheBlueMule's Avatar
TheBlueMule is starting off with a positive reputation.
Quote:
Originally Posted by danlee
The difference between +0.030, and +0.040 is only 2 cubic inches, so there is little performance to be gained. The availability and cost of the pistons in those overbores would be a bigger factor in my opinion. I went with +0.030" because it is a common size. Tim Meyer lists +0.030" and +040" in his piston section.
These blocks are relatively cheap. If you ever need to rebore it, you would probably start with a fresh block.
I didn't think that there was much difference in power between the two bores. I also thought about buying another block if needed next time but I think I'll stick with the .030 bore. I'm sure I'll have somemore questions with my rebuild mods once I get it bored.
Thanks guys
TheBlueMule
__________________
1979 F-250 4x4 4spd 351m. Under Resto!!
1989 F-350 4x4 dually 4door 7.3 Banks Sidewinder E4OD transcommand 5" bullhorn straight piped stacks custom bumpers xm diamond plate interior
2001 F-1150 "Big Red" 3208 turbo cat Allison crew cab air dvd/nav best of everything!
2008 Warrior conv. Mustang
Sponsored Links
To remove this ad, register today!
  #152 (permalink)
Old 03-26-2008, 12:00 AM
hollenjoe is starting off with a positive reputation.
People around here reman their blocks by putting new sheves into their cylinders returning the engine to a standard bore.... it costs around 200 bucks and your block is as good as new....
__________________
"All right baby, see what I´ve got right here in my hands, I´ve got it right in my hands to score you baby, I think im gonna yank on a one town! Look Out!" Uncle Ted
  #153 (permalink)
Old 03-26-2008, 12:30 AM
mustang81 is starting off with a positive reputation.
i put 3 new one and bore .030, since i already have my piston .030
  #154 (permalink)
Old 03-26-2008, 05:22 AM
roger dowty is gaining momentum as a positive member of FTE.roger dowty is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by hollenjoe
If you shaved your heads simply go with a slighltly bigger cam to lower your dcr
right...however then your putting the cart before the mule so to speak...ie build the engine around the cam and thus performance that you want...
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
  #155 (permalink)
Old 03-26-2008, 07:36 AM
benshere is starting off with a positive reputation.
cylinder sleeves
Glad you guys brought up the sleeve thing--. Question I have had for a long time but never thought to ask.
Can thicker sleeves be put in that become "siamese" and allow a larger bore (~4.18") like the SVO blocks? Just think of the cubes that would allow with a 4+ stroke! Inquiring minds want to know!
  #156 (permalink)
Old 03-26-2008, 07:46 AM
danlee's Avatar
danlee has a good reputation on FTE.danlee has a good reputation on FTE.
You need some cylinder wall left to install sleeves. You can't make the cylinder OD larger than it has been cast.
You would have to cut apart the block to do that. There may be some avant-garde welding tricks that would allow that, but not on a practical level.
__________________
JOIN THE DELAWARE CHAPTER, CLICK HERE
  #157 (permalink)
Old 03-26-2008, 10:43 AM
Siamese blocks
Ah come on Dart/SVO/SOMEBODY, cast a 10.297 siamese block with small bell pattern and option a deck plug for C or W style heads
  #158 (permalink)
Old 03-27-2008, 11:10 AM
mzulkoski is starting off with a positive reputation.
These links may be of some interest. Might help dispell some of the 351M myths.
http://www.projectbronco.com/Technic...e_build_up.htm
http://www.fordcobraengines.com/Modified%20History.htm
http://home.earthlink.net/~bubbaf250/
I will soon start the frame-off restore of my father's 77 F100 Ranger (short bed - step side). He purchased it new in 77. 351M with 400,000 + miles and still going strong!
Mike from Ord, NE
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
