Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-10-2007, 02:28 PM
buffalobob is starting off with a positive reputation.
whats the best block sealer ?
I have an old truck that I had to braze some studs into the exhaust bolt holes -because the PO broke off the castings where the bolts screwed in.....I eliminated a very bad exhaust leak - but the heat and the funkyness of cast iron produced a very small coolant leak - at one spot - where its brazed......just enough to create small whisps of steam on the hot cylinder head -
anybody know of a really good sealer to add to coolant to plug the leak?.....I have used Silver Seal in the past on other vehicles but not for years.....wondering if something new /better is out there.....
changing the head is not an option - Im sure its NOT leaking into the engine- I removed the plug and no indication of a problem - the outside of the head coolant passage is whats involved here
thanks in advance
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-10-2007, 03:45 PM
kermmydog's Avatar
ARIZONA CHAPTER MEMBER
kermmydog has a great reputation on FTE.kermmydog has a great reputation on FTE.kermmydog has a great reputation on FTE.kermmydog has a great reputation on FTE.kermmydog has a great reputation on FTE.
Alumiseal If done correct will seal it. But I have found getting the engine warm, add to warm coolant. Let it run for sometime. Alumiseal will settle if not put in a warm engine and circulated real good.
  #3 (permalink)
Old 12-13-2007, 08:56 PM
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
K&W sealant will do the trick also. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #4 (permalink)
Old 12-14-2007, 04:02 PM
tjc transport's Avatar
find me if you can!!!
tjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant future
blue devel is the absolute best. i have used it for blown head gaskets on 3.8 fords, 3.1 chevys, and blown intake gaskets on GM V6's. follow the directions, and you will never have any problems with it again.
__________________
Join me in the New Jersey Chapter, CLICK HERE!
NEW JERSEY CHAPTER LEADER
Tom
65 falcon 2dr h/t hot 289/C4
66 7 litre 4 speed convertible
79 F250 4X4 plow rig 351M C6
88 superduty diesel 4X4 C6 and banks turbo
99 crown vic P71 interceptor
02 F250 superduty diesel 4X4 stretchcab shortbox, all better now!!
  #5 (permalink)
Old 12-16-2007, 04:03 PM
Twistin's Avatar
Twistin is starting off with a positive reputation.
Bar's Leak, heavy duty stop leak. the one with the pellots. trick is shake the bottle to loosen the pellots, then top off radiator then drive it. the flow and heat will get the product thru the system. Ive even sealed bad head gaskets with this stuff untill i could get to it and change them. my 2 cents.
Keep Em' Twistin'! Bob B.
Bronco Stables: 89 thru 96 / XLT / Eddie B / BR II
http://www.supermot ors.net/vehicles /registry/ 15608
thanks in advance
  #6 (permalink)
Old 12-17-2007, 04:02 PM
kermmydog's Avatar
Question
Quote:
Where do you buy blue devil? That is a new one I have never heard of. Any info greatly appreciated.
Craig
  #7 (permalink)
Old 12-17-2007, 04:34 PM
merlynr is starting off with a positive reputation.
Hey Buffalobob, try some JB Weld on the outside.
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
05 Mustang GT 5 sp
73 Mustang cpe
71 Mustang cpe
65 Mustang fastback
  #8 (permalink)
Old 12-17-2007, 04:51 PM
i get it from napa. but a quick google search found this
http://www.autobarn.net/blue-devil-e...g-sealant.html
that is the same price as at napa.
a 32 oz bottle will usually treat 2 smaller engines.
Quote:
Craig
__________________
Tom
  #9 (permalink)
Old 12-19-2007, 01:19 AM
kermmydog's Avatar
Smile
Thanks for that info. I never saw it at Napa but I'll ask the next time I go in. I have an account with my local Napa so they get the bulk of my business.
  #10 (permalink)
Old 12-19-2007, 09:29 AM
most stores do not carry it as an on the shelf item, but can order it.
__________________
Tom
  #11 (permalink)
Old 01-27-2008, 04:15 PM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
http://www.devcon.com/devconfamilypr...m?familyid=124
For some things like this instead of wleding to build up and area these new
generations of titanium epoxy are miracle workers. I even had a rear shock
on a motorcycle repaired with it, the chrome was rusted and the shaft was
eaten away pretty deep made it lose all the oil and tore the seal a bit of
this and some grinding brought it back to spec abeit with a non chromed
area but it has no problem.
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
  #12 (permalink)
Old 03-03-2008, 01:21 PM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
water glass or sodium silicate is thw best I've ever used but can't remember if it's compatable with anti-freeze
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #13 (permalink)
Old 03-04-2008, 08:56 AM
Quote:
We used to use sodium silicate(egg preserver) mixed with flax seed. This would stop a large leak. This is the main ingredient in K&W without the flax seed. We use K&W for cracked heads, head gaskets. If done properly, it will stop a large leak. jd
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
