2005 F-250 diesel issues - Ford Truck Enthusiasts Forums
Old 12-09-2007, 11:30 PM
beyacork beyacork is offline
beyacork is starting off with a positive reputation.
<TABLE><TBODY><TR><TD vAlign=top width="100%">I have an F-250 with 36,500 miles on it. I am currently getting a PO401 code with the engine light on. I took it to the dealer several months ago and they told me it was my aftermarket intake causing the problem (K&N). They charged me $95. They reset the DTCs and the light went away. A few days later, it came back. I recently purchased a code reader from carmd.com. It displayed the 401 code. This code suggests something other than my air intake. Since that visit to the dealer, I cleaned the air filter, thinking that that was the problem. Since I didn't have a code reader at the time I took it in, I don't know if I am getting the same code as the dealer did. Anyway, I am experiencing hesitation and the engine acts like it's lugging. I floor it and the rpms increase, but the exceleration is just not there.
For background info, the vehicle has had two turbo replacements, one alternator, two heads, one EGR valve at least 10000 to 15000 miles ago, and one catalytic converter. Over its life, I have brought the vehicle in several times complaining of lack of power, and it seems like they fix it, but the problem or some problem seems to return within a few months. Any suggestions?????? I am getting rather frustrated by this whole situation. My previous vehicles were used (ranger, F-150) and I did not experience anything like this.
beyacork
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- Ken 2-8-2007: only if not club fte member in --><TD vAlign=top align=right width=300>******** type=text/javascript> <!-- // Add region, percent, channel, hints Display300x250( 115, 65, "3940151663" ); //--> *********>******** src="http://pagead2.googlesyndication.com/pagead/show_ads.js" type=text/javascript>*********>******** name=google_ads_frame marginWidth=0 marginHeight=0 src="http://pagead2.googlesyndication.com/pagead/ads?client=ca-pub-9465106892657534&dt=1197260939593&lmt=1197260939&a lternate_ad_url=http%3A%2F%2Fcampaigns.ford-trucks.net%2Fcampaigns%2F300x250.html&format=300x2 50_as&output=html&correlator=1197260939593&channel =3940151663&url=http%3A%2F%2Fwww.ford-trucks.com%2Fforums%2F682963-2005-f-250-diesel-issues.html&color_bg=FFFFFF&color_text=000000&colo r_link=0000CC&color_url=0000FF&color_border=FFFFFF &ad_type=text_image&ref=http%3A%2F%2Fwww.ford-trucks.com%2Fforums%2Fforum30%2F&cc=100&ga_vid=245 195691.1197254840&ga_sid=1197260878&ga_hid=1409824 824&ga_fc=true&flash=9&u_h=960&u_w=1280&u_ah=922&u _aw=1280&u_cd=32&u_tz=-480&u_his=4&u_java=true" frameBorder=0 width=300 scrolling=no height=250 allowTransparency>*********>
</TD></TR></TBODY></TABLE>
Old 12-10-2007, 01:25 AM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
P0401: Exhaust Gas Recirculation Flow Insufficient Detected
EGR Valve Position does not match desired, limits based on engine speed/load.
It appears your EGR valve is sticking, the EGR valve position sensor is bad or the EP sensor is bad.
A/M air filters tend to make FMC & dealers void your engine warranty. The K&N system is probably the worst A/M air filter you could have chosen for the 6.0.
Old 12-10-2007, 03:57 PM
big inch big inch is offline
big inch has a good reputation on FTE.big inch has a good reputation on FTE.big inch has a good reputation on FTE.
You will probably need a new egr valve to correct the problem.
If you still have the stock air filter, put it back on and then take the truck to the dealership (or another dealership).
Old 12-10-2007, 04:22 PM
What type of air intake would you recommend for the 6.0. And, what is the problem with the K&N system?
Old 12-10-2007, 04:26 PM
powerstroke1350's Avatar
powerstroke1350 powerstroke1350 is offline
powerstroke1350 is starting off with a positive reputation.
k&n is not good for anything. its cheap crap. AEM and AFE, these are good intakes.
Old 12-10-2007, 05:43 PM
Quote:
Best air intake for the 6.0 was installed by FMC. The OEM Donaldson Powercore has the best filtration of any filter on the market, provides more air flow than the 6.0 can use until you reach 500+RWHP (this takes more than a tuner), holds over 3lbs of dirt, and can last up to 80k miles. Change filter based on the filter minder on the air box.
There have been Air Filter tests done and the K&N systems always rank at the bottom of the list for filtration ability. On a turbo charged engine, dirt through the turbo is not a good thing as it shortens the life of the turbo and other components. Also the K&N filter is a wet oil type, which is hard on the engine sensors in the air stream.
Old 12-10-2007, 06:38 PM
MattyNJ's Avatar
MattyNJ MattyNJ is offline
MattyNJ is starting off with a positive reputation.
I cant even imagine having had all those horrible issues with that truck already!! what the hell do you do with your truck? I have the same year truck with no problems to date (knock on wood). Good luck, no offense but stay away from me huh....in case its contagious!
Old 12-10-2007, 08:57 PM
2005 warranty repairs
Quote:
The truck is basically stock, 4" exhaust and the K&N air intake, no lift kit and it has stock tires. On the turbo, they tell me moisture is getting into the turbo and rusting the innerds, causing valves to stay open giving too much turbo boost. The intercooler pipe has blown off at least 5 times. I live in Bakersfield, Ca which is fairly dry. Do I have a lemon??????? I spoke to a gentleman at britebox.com. They build light kits for various vehicles. The box allows the brights, dims and fogs to stay on at the same time. He told me all kinds of stories regarding 2004s, 2005s, and 2006s. He told me about an auto web site to check out which details many articles about several warranty issues similar to mine. It's not Car & Driver, but it's one of the sights that came out originally in magazine form, autoweek, maybe??? He said to beware of the 2008. For certain maintenance issues, the cab has to be pulled. The headlights are computer controlled. If the computer experiences two failures, it has to be replaced (no curcuit breaker here). There is also some front end issues with the stabilizer shock. I think it applies more to the lifted trucks as I have not experienced this problem. But when you hit a pothole just right, you loose steering control.
Back to my issues, I pull a 7200 lb. travel trailer, maybe, once to twice a month. I use a superchips programmer to increase the hp, but I never go over the economy mode. I have only owned the unit for a year. These problems have occurred over the life time of my ownership of this truck.
Old 12-10-2007, 09:16 PM
I went to AMSoil.com to look at the powercore. Their price is $71 for the air filter and it looks like it fits into the stock box. Based on what you're telling me, I should see more performance out of this filter using the stock box than I do from the K&N. Is there any articles you can direct me to regarding this?
Thanks.
Beyacork
Old 12-10-2007, 10:03 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
The points are:
1) You do not get any extra performance w/ a different intake if you do not have other mods. For up to 500 RWHP, the OEM air system is more than sufficient in air supply. Do some searches and you will find actual references where you can read the study results yourself. Do not get your air filter at AMSOIL - plenty of OEM places to get them so that you can be sure they filter as designed.
2) The dealership told you the aftermarket intake is causing your problems - believe them! The oil on the K&N filter is a problem with sensors. The K&N does not filter as well so you get sticking vanes in your turbo (dust, moisture, etc). This can and, more often than not, causes over boost and head gasket problems (and warped heads).
"Stock" definitely means no aftermarket air intakes.
Old 12-10-2007, 10:19 PM
Thanks for your help. beyacork
Old 12-10-2007, 10:59 PM
bismic's Avatar
I haven't found the filtration tests yet, but here is one reference on intakes:
http://www.fourwheeler.com/techartic...350/index.html
"The benefits of a big-bore, mandrel-bent exhaust are well documented. Magnaflow's 4-inch stainless system incorporates all of the best technology to maximize exhaust flow. Along the same lines, the Airaid cool-air high-flow intake system increases intake breathing in a major way.
"Why then," you ask, "did you only pick up only 8 hp by installing both?"
Good question.
When a free-flow intake and exhaust really become necessary is when the engine's power output increases due to increased fueling, boost, and timing from a chip or a fuel-injection programmer. To make that extra power, you need more airflow in and out. Changes in programming alone may quickly overcome the stock truck's inability to breathe. This will then limit the potential output from the chip or tuner and usually cause EGTs to rise to terminal levels more quickly in any situation.
<TABLE cellSpacing=2 cellPadding=2><TBODY><TR><TD colSpan=3>Rear-Wheel Horsepower and Torque</TD></TR><TR><TD colSpan=3>DynoJet 224 Chassis Dyno*</TD></TR><TR><TD colSpan=3>Dyno Test Results: 05 Ford F-350 Super Duty 6.0L, SR100 five-speed automatic</TD></TR><TR><TD>Condition</TD><TD>Power</TD><TD>Torque</TD></TR><TR><TD>Stock, with 800 miles</TD><TD>275.6 hp</TD><TD>469.6 lb-ft</TD></TR><TR><TD>With Airaid & Magnaflow</TD><TD>283.9 hp</TD><TD>477.2 lb-ft</TD></TR></TBODY></TABLE>
Old 12-10-2007, 11:28 PM
bismic's Avatar
here is some info on the AIS Powercore filter
http://www.powerstrokeregistry.com/page20.html
What the Power Stroke Diesel does demand is good clean fuel, quality clean oil, and clean air - three ingredients that lead to long engine life.
The new AIS Severe Duty kit with Donaldson PowerCore technology is especially beneficial for those who work in demanding environments. In fact, the Abrams M1A2 tank uses PowerCore air filter technology to make sure its 1,500-horsepower gas turbine engines always get clean air in all environmental conditions, including desert dust storms. Most of us will not put our Power Stroke Diesel powered vehicles through the same conditions as a battle tank, but we may endure some of the same dirty, dusty on- and off-road conditions that can eat up regular air filters in no time flat.
When you look at an AIS Severe Duty filter, you may notice its unique appearance, shape and straight-through air flow design. The AIS Severe Duty filtration device looks a lot like boxboard or cardboard. In fact, similar technology is used to corrugate layers of media into narrow channels or "flutes." Opposite ends of each flute are later sealed, turning the layers of flutes into a high-density filter. The airflow goes in one end of the filter and out the other, passing through the high tech material along the way.
The straight-through design results in lower restriction due to fewer air-flow directional changes. Lower restriction means improved equipment operation and longer filter life. Other aftermarket filter suppliers can claim lower restrictions, many by offering washable filters, but usually at the expense of harmful dirt and soot getting into the engine.
The AIS Severe Duty filtration utilizes Web Nano-fiber technology, which results in contaminant filtration that is over 400 times more efficient than a comparable washable filter. Put another way, a washable filter will allow over 400 times the amount of harmful and abrasive dust and contamination to be drawn into the engine, resulting in increased engine wear.
In comparison to a washable filter, the AIS Severe Duty filter has 17 times the amount of filtration area. This is one of the reasons that the PowerCore filter holds so much more dust. More filter media area increases dust capturing and holding capacity and keeps filters from clogging up.
In addition, the AIS Severe Duty filter holds almost five times the dust of a comparable washable filter. This means that a washable filter will plug up faster and your engine will work harder to pump air, as opposed to the AIS Severe Duty filter.
Old 12-11-2007, 10:00 PM
Mark, thanks for all your help and advice. Today, I reinstalled my stock air filter and plumbing. I am going to take it back to the dealer for service and hopefully get the egr sensor replaced if that is the problem with my lack of power and hesitation.
Old 11-03-2010, 02:28 AM
71cudaman 71cudaman is offline
71cudaman is starting off with a positive reputation.
2005 6.0
Quote:
hey man ive got a 05 6.0 and only nroke on me once egr valve went out and the symtons were blue smok like crazy no power would start and idle' they thought it was a injector' anyways they had too clean the turbo,egr cooler,intake alot of things. so if ur truck isnt doing that then prob not the egr, bro.... ive heard the injectors are the prob on the 6 liter'
Help...7.3 e350 thermostat replacement,abs ,starting bcmedic1 1999 - 2003 7.3L Power Stroke Diesel 2 12-08-2007 09:20 PM
Intake Air/Exhaust Manifold Preheat Shroud Imdok Ford Inline Six, 200, 250, 4.9L / 300 3 10-11-2007 02:11 PM
2002 windstar 3.8 L Code p0401 texx101 General Automotive Discussion 1 08-15-2007 01:57 PM
por-15 vs. chassis black uncle2abc Paint & Bodywork 3 03-04-2007 11:46 PM
Help with 7.3l powerstroke vibration exdriver 1999 - 2003 7.3L Power Stroke Diesel 14 02-02-2007 07:53 PM
Tags
2005, 60, air, catalytic, converter, diesel, diesels, ep, f250, f350, filters, ford, issue, issues, kn, problems, sale, sensor, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
