I just picked up a superduty rear for a 100 bucks, 4.10 LSD. I was wondering if there is a way to transplant the rear discs to mine, without using the 8x170 bolt pattern or not.
Yes there is. Wheel spacers that adapt from 170mm to 6.5. Thats what I would do! That would solve the bolt spacing and also correct the narrow track width on the rear
That's right I didn't even think about that. I have fender Flares on it and wanted spacers anyhow, now I have an even better reason for them, thanks TJ
i have doen some measuring and the rear itself should bolt right in, the only problem is the driveshaft yoke, i havent had tuime to see if you could just swap the 10.25 yoke for the 10.5
Joe it should be pretty easy to find a u-joint that will fit the SD yoke and the OBS drive shaft. it will just take some time with a knowledgeable part guy who knows how to use the u-joint book.
