In general it would seem that the freer flowing an exhaust, the louder it would be. Sure there are exceptions, such as noise cancellation technology and rice boy noise maker exhaust tips, but for general exhaust work that us normal folks do, it makes sense that quieter = more restriction and louder = freer flowing. So is it a reasonable assumption that if you modify your exhaust and it gets louder, that you therefore have a freer flowing system?
you could get a high flow cat and a different muffler.
__________________ 94 ranger 4x4 auto
138,000
31x10.5x15
intake
T-cover
had cherry bomb turbo muffler, flowmaster series 40 (used about 2-3 months make offer clampped on) now cherry glasspack.
2x55w offroad lights in grill
CD with 4 new speakers
500 watt sub w/1500watt amp (has alotta bump in back of seat.)
Tints %20 front %5 back
And the Magnaflows are among the least restrictive, and often they are amazingly tame sounding.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
Yeah, so a tough and dirty rule of thumb, louder is freer, but not necessarily.
Well I figure the cat is a restriction, but so is the muffler. And if the change to a performance muffler makes it louder, then some restriction was relieved, though more could be relieved if the cat were changed too.
Why would mileage have anything do do with anything? Some of the earlier converters were more restricitive, but mileage is irrelavent.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
I would guess the mileage thing is assuming that more miles = more deposits in the converter = more restrictive. But do deposits collect in the converter? It supposedly runs very hot, perhaps too hot for deposits.
Moving parts don't last forever. A catalytic converter is not a moving part. My experience, is they will last at least as long as the vehicle so long as the vehicle is maintained correctly. My dad still has his original converter on his Ranger and his Prism, bot vehicles have over 300,000 miles and both easily pass emissions.
In order for a converter to fail, their either has to be something wrong with the engine which causes the converter to overheat or plug up, or their has to be a design flaw to begin with that causes physical damage to the substrate.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
And in my experience, the inside of the cat we took out of my Dads Ranger actually fell apart when I set it on the workbench. Ran fine AND passed emissions as well. The truck runs clean enough to pass without the cat. Less than 100k.
Didnt mean the cat was good though. This truck was maintained better than 99% of the vehicles out there.
__________________
1964 F100- Gonna see boost
1998.5 Ford Contour- Many mods
I deal with over a thousand dead converter per month, and the vast majority show signs that they were either melted, plugged up, or rattled loose. Rattled loose is sometimes caused by physical damage, but more often is a design defect. It sounds like you fathers meets that criteria. It fell apart because it was already broken because the packing around it failed. Failure of that kind is not related to mileage, they can go anytime, be it 10,000 miles or 1,000,000 miles. It is related to heat however, heat causes the packing to fail if it of low quality (which most are) and when combined with excessive size (many OEM designs meet this criteria as well) it causes and expansion differential which gradually damages the packing.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
