1999 f250 7.3 water pump replacement
on
Here is a step by step instruction on how to do it.. I guess the hardess part is getting the large nut loose on the fan.. see:
http://www.diesel-central.com/News/waterpump.htm
Welcome the Forum
Welcome the Forum
I ended up purchasing the special wrench for the big shaft nut, biggest part is having something to hold the shaft from turning when you first break it loose. Also the water pump mounting bolts are three different lengths, so keep track of which ones go where. I also found some Dow Corning 111 silcon grease handy to hold the pump
O-Ring gasket in place when it was being mounted.
I also had problems with removing the fan when I changed the water pump on my truck. But, when I replaced the pump on my dads truck, he had talked to a diesel mechanic, and he informed him of a simple way to get the fan off. He said to take an air chisel with the flat blade and place it toward one of the corners of the nut and squeeze the trigger and it will come right off. So I tried it and within 15 seconds I had his fan off. That trick worked like a charm for me. Hope this helps
Originally Posted by powerstrokinsmokin
I actually used a pipe wrench for the big nut. keep the belt in place and its right handed thread. just hit the pipe wrench with a hammer and mine loosened rightup. pretty easy i thought. make sure the mating surface is clean before install.
removing the radiator and shroud give a lot more room to work
I also replaced the thermostat as the housing gasket is part of it
Originally Posted by 19stroker99
are thes water pumps on e-bay any good
7.3 POWERSTROKE FORD DIESEL WATER PUMP NEW AW4114
I bought this one 65k ago and it still is working fine. Airtex makes water pumps for the big three auto makers. Don't let ford mark these up to $300 and sell it to you. I paid $92 with shipping.
Product Detail
Airtex Ford, Jaguar & Mazda Water Pumps
<TABLE cellSpacing=1 cellPadding=5 width="100%" border=0><TBODY><TR><TD vAlign=top>E-MAIL THIS PRODUCT TO A FRIEND
Price: $85.99
1996 - 2003 Ford 7.3L Turbo Diesel engines. This pump fits the 1996 through 2003 model Direct Injection Turbo Diesel models. Pump contains new bolts, plugs, gasket and installation instructions!
<TABLE style="FONT-SIZE: 8pt; WIDTH: 494px; HEIGHT: 97px" height=97 cellSpacing=1 cellPadding=1 width=494 bgColor=#ffffff border=0><TBODY><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD>
</TD><TD>
</TD><TD colSpan=2>
</TD><TD>
</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD>
</TD><TD>
E550 and E Super Duty Vans
</TD><TD colSpan=2>
</TD><TD>
</TD><TD>
</TD><TD colSpan=2>
</TD><TD>
</TD><TD>
</TD><TD colSpan=2>
</TD><TD>
</TD><TD>
</TD><TD colSpan=2>
</TD><TD>
</TD><TD>
</TD><TD colSpan=2>
</TD><TD>
</TD><TD>
</TD><TD colSpan=2>
</TD><TD>
</TD><TD>
</TD><TD colSpan=2>
</TD><TD>
</TD></TR></TBODY></TABLE>
Category:
Water Pump, Gskt, Fan & Clutch
Manufacturer:
Airtex Water Pumps
Model Number:
AW4114
