1999 f250 7.3 water pump replacement - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-09-2007, 03:37 PM
19stroker99 19stroker99 is offline
19stroker99 is starting off with a positive reputation.
how hard is the water pump to replace on 1999 f250 7.3
any thing special i need to know before tackling this job
also is there any step by step instructions thanks in advance for any info
Old 12-09-2007, 03:50 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
Here is a step by step instruction on how to do it.. I guess the hardess part is getting the large nut loose on the fan.. see:
http://www.diesel-central.com/News/waterpump.htm
Welcome the Forum
Old 12-09-2007, 03:51 PM
Alpine6 Alpine6 is offline
Alpine6 is starting off with a positive reputation.
Pretty simple really. I had the hardest time seperating the fan from the waterpump. I ended removing it as a unit and taking it to a shop and having them take it apart.
Let us know if you run into any problems, but I don't see you having any issues. Buy a new waterpump, not a reman.
Old 12-09-2007, 07:33 PM
stormyrider stormyrider is offline
stormyrider is gaining momentum as a positive member of FTE.
I ended up purchasing the special wrench for the big shaft nut, biggest part is having something to hold the shaft from turning when you first break it loose. Also the water pump mounting bolts are three different lengths, so keep track of which ones go where. I also found some Dow Corning 111 silcon grease handy to hold the pump
O-Ring gasket in place when it was being mounted.
Old 12-09-2007, 08:37 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
zx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant future
I opted to pull the radiator to give more room to work. Don't know how much it help, but it's not that hard to pull and I did have plenty of room to work. Not too hard to do. Good luck and let us know if you run into any problems.
Old 12-09-2007, 08:42 PM
powerstrokinsmokin's Avatar
powerstrokinsmokin powerstrokinsmokin is offline
powerstrokinsmokin is starting off with a positive reputation.
I actually used a pipe wrench for the big nut. keep the belt in place and its right handed thread. just hit the pipe wrench with a hammer and mine loosened rightup. pretty easy i thought. make sure the mating surface is clean before install.
Old 12-09-2007, 09:10 PM
morrisracing morrisracing is offline
morrisracing is starting off with a positive reputation.
I also had problems with removing the fan when I changed the water pump on my truck. But, when I replaced the pump on my dads truck, he had talked to a diesel mechanic, and he informed him of a simple way to get the fan off. He said to take an air chisel with the flat blade and place it toward one of the corners of the nut and squeeze the trigger and it will come right off. So I tried it and within 15 seconds I had his fan off. That trick worked like a charm for me. Hope this helps
Old 12-10-2007, 10:13 AM
are thes water pumps on e-bay any good
7.3 POWERSTROKE FORD DIESEL WATER PUMP NEW AW4114
Old 12-10-2007, 10:22 AM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
Quote:
that is the way I done it as most of my tools were 750 miles away
removing the radiator and shroud give a lot more room to work
I also replaced the thermostat as the housing gasket is part of it
Old 12-12-2007, 08:50 AM
I replaced the water pump with out any problems thanks for all the help this is a great site save me a lot of money.
Old 12-12-2007, 08:55 AM
zx250's Avatar
Good to hear, Hang around and you will find out a lot more about your truck and engine.
Old 12-12-2007, 08:57 AM
rugermack's Avatar
rugermack rugermack is offline
rugermack is gaining momentum as a positive member of FTE.rugermack is gaining momentum as a positive member of FTE.
I bought this one 65k ago and it still is working fine. Airtex makes water pumps for the big three auto makers. Don't let ford mark these up to $300 and sell it to you. I paid $92 with shipping.
Product Detail
Airtex Ford, Jaguar & Mazda Water Pumps
<TABLE cellSpacing=1 cellPadding=5 width="100%" border=0><TBODY><TR><TD vAlign=top>E-MAIL THIS PRODUCT TO A FRIEND
Price: $85.99
1996 - 2003 Ford 7.3L Turbo Diesel engines. This pump fits the 1996 through 2003 model Direct Injection Turbo Diesel models. Pump contains new bolts, plugs, gasket and installation instructions!
<TABLE style="FONT-SIZE: 8pt; WIDTH: 494px; HEIGHT: 97px" height=97 cellSpacing=1 cellPadding=1 width=494 bg*************** border=0><TBODY><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD>
Make
</TD><TD>
Model
</TD><TD colSpan=2>
Year
</TD><TD>
Application
</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD>
FORD TRUCK
</TD><TD>
E100- E350 Super Duty, E450,
E550 and E Super Duty Vans
</TD><TD colSpan=2>
03-96
</TD><TD>
V8 446 (F) (7.3L) (Diesel)
FORD TRUCK
</TD><TD>
Excursion
</TD><TD colSpan=2>
03-00
</TD><TD>
FORD TRUCK
</TD><TD>
F100, F150, F250, F350 Pickup
</TD><TD colSpan=2>
97-96
</TD><TD>
FORD TRUCK
</TD><TD>
F250/350/450/550 Super Duty Pickup
</TD><TD colSpan=2>
03-99
</TD><TD>
FORD TRUCK
</TD><TD>
</TD><TD colSpan=2>
1997
</TD><TD>
V8 446 (F) (7.3L) (Diesel) VIN F
FORD TRUCK
</TD><TD>
</TD><TD colSpan=2>
1996
</TD><TD>
FORD TRUCK
</TD><TD>
F59 Stripped Chassis
</TD><TD colSpan=2>
97-96
</TD><TD>
F59 Stripped Chassis (Diesel)
</TD></TR></TBODY></TABLE>
Category:
Water Pump, Gskt, Fan & Clutch
Manufacturer:
Airtex Water Pumps
Model Number:
AW4114
Old 05-10-2010, 05:15 PM
adampettit adampettit is offline
adampettit is starting off with a positive reputation.
Water pump leak
I need someone to tell how to fix a leak on the t-stat housing on a water pump for a 2000 7.3
Old 05-10-2010, 05:22 PM
It's best to start a NEW thread, using T-stat housing as the "subject" ... this one pretty old..
Also, you can use the "Search" to find the answer.... And a big welcome to the Forum
Old 05-10-2010, 05:30 PM
zx250's Avatar
Welcome to the site, and Clint is right, this is an old thread. A new one started by you will get a lot more attention. I'm really not sure what to tell you, but you will get lots of good advice from them folks.
1999 F250 7.3l won't start DavidLM11 1999 - 2003 7.3L Power Stroke Diesel 10 02-28-2016 08:12 PM
Over heating 99' 7.3 halaferd 1999 - 2003 7.3L Power Stroke Diesel 21 08-28-2015 08:30 AM
1999 FORD F250 7.3 DIESEL.... WONT START coastal stone 1999 - 2003 7.3L Power Stroke Diesel 15 04-12-2011 10:49 PM
Water Pump Removal? Rus01 1999 - 2003 7.3L Power Stroke Diesel 21 08-25-2009 10:55 PM
1999 F250 V10 6.8 water pump installation??? BajaRacer909 Modular V10 (6.8l) 2 12-28-2005 10:37 AM
Tags
1999, 2001, 73, bad, change, clutch, cost, diesel, f250, f350, fan, ford, pump, replace, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
