12-09-2007, 03:28 PM
2000 F250 5.4 SD low idle speed
Idle speed is usually around 750 but currently is closer to 450. When starting, acceleration is required to keep the engine running until it warms up a bit. Then it idles at 450. Following acceleration, it will die if assistance via gas pedal is not given. This problem would occur occasionally in the past, once every 6 months or so but would return to normal (750 rpm) idle after a few minutes. Currently idle is remaining at 450 rpm. I thought it might be the air idle control. Any suggestions? And does anyone have pictures of the AIC for this model.
