Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 12-24-2007, 09:49 AM
benshere is starting off with a positive reputation.
3 speed OD
I never had one of the 3 speed OD's but knew someone with a 65 fairlane w/289 (I think it was a Hi Po if it was produced in them). Seems that that tranny was frequently breaking. Dont know what about it was the weak link.
NumberDummy--Can you verify that GM used the ford 3 speed behind its HiPo engines as the "standard" tranny. Pretty sure one of my friends w/67 GTO verified that his 3 speed was a ford. You know that hurt him! The first 64 GTO I ever rode in was a 3 speed as well (Gainesville, fl). Think it was because of fire at a GM plant somewhere.
Also recall a 3 speed OD in an old V8 Studebaker ~59 wagon. That was before I had to learn about the underneath side of cars----kinda giving away my age!!
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 12-24-2007, 09:16 PM
68 351 bronc is starting off with a positive reputation.
Big Dummy,(no offense) That Galaxie 500xl (HT) Hard Top & (FB) Fast Back with FE Is the stuff that makes me wish I were born 20 years earlier. I am a 68 model same as my Early Bronco.
Ha ha. Merry Christmas All!
__________________
2001 F250 V-10 auto XLT 4X4
68 Bronco GT40 351w, NV3550 5sp, sweet!!!
  #18 (permalink)
Old 12-25-2007, 04:04 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
The only FIRE occured in 1953-see below.
Careful when asking the big Dummy a question, you'll get more info than you bargained for!
O/D in passenger cars in the 1960's: 1960/67 Galaxie ~ 352 engine only / 1962/67 Fairlane 221/260/289...but O/D could not be ordered with the 289/271 HP HiPo engine = Ford 4 Speed Top Loader only.
Studebakers used B/W T-86 O/D's in passenger cars, except the Packard engined 1956 Golden Hawks, which used T-85's. 1955/56 Packards used the same transmission which is...the SAME transmission used in Galaxies, F100's 55/57 Birds, others.
The Studebaker O/D: relays, governors, solenoids, and in some cases, the kickdown switch are the same ones Ford used on various models. I typed all the comparable Studebaker/Packard/Ford part numbers a while ago.
While no O/D parts are available from Ford, NOS O/D parts are available from Studebaker parts vendors. (The big Dummy has all the Studebaker & Packard parts catalogs = because many moons ago, prior to working as a Ford partsman, the Dummy was a Studie partsman).
The Ford 3.03 all syncro 3 speed was actually made by Borg-Warner. A similar trans was used in some GM cars.
FIRE!
In 1953, the GM Hydra-Matic factory burned to the ground. So, some 1953 Cadillac's and Olds' use the Buick Dyna-Flow trans, Pontiacs used Chevy's Power-Glide. How do you tell what trans is in 1953 Cads and Olds?
The give-away = Dyna-Flow has a Parking gear (P in the shift quadrant). No Hydra-Matic had a Park gear till the Jet-Away Hydro first offered on 1956 Cadillacs, Olds 98's. Jet-Away was optional on Olds 88's and Pontiacs. After 1956, Jet-Away was standard equipment on these three cars. Jet-Away = POS!
All 1940/55 and some 1956 Hydra-Matics have a geared reverse, so when parking, just put the H/M's shift lever there, the car won't roll = guar-an-teed.
When the Hydro factory burned down, GM moved production to the former War Production Board built factory in Willow Run, MI that was leased to FoMoCo to build B-24 bombers in WWII. Willow Run was leased to Kaiser-Frazer in 1946/53, where K-F assembled all their cars. When GM took over the factory, Kaiser production moved to Toledo, Ohio, where Willys cars and Jeeps were assembled. Kaiser bought Willys in 1952.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #19 (permalink)
Old 12-25-2007, 09:42 AM
Information
Thanks ND!
Absolutely not too much----
You have answered a lot of questions that have been on my mind for many years! Knew some about the Jet-aways, except for POS, they had better (more) gearing. The Studebaker was dads and a v8 wagon w/3speed OD. Remember now the "lift the foot" for OD and lots of slack in the DL. Dad also (at some point) had a "Willys" cracker box w/OD tranny, which I tore up regularly. Usually something else also got "Torn up"
56 GMC truck w/3 speed, no OD was a family truck (Dad ran a farm supply store in NW fl) Allis Chalmers, Massy-Fergeson (was selling Fergeson tractors when they merged w/Massy Harris. Hot tip for Powerglide owners was to find a 6 cyl GMC with a Hydramatic (chevy 6) and grab the bellhousing for your sblock chebby then swap in a hydramatic. V8 GMC was a Pontiac, 6 was a chebby(?).
Sorry for the long post, but what the ####, its christmas---- BTW Merry Christmas. If you are offended, TS
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
