wont come out of 4 wheel drive - Ford Truck Enthusiasts Forums
Old 12-08-2007, 06:40 PM
6ohin25401 6ohin25401 is offline
6ohin25401 is new and has a neutral reputation at this point.
had to put to use my 4 wheel drive this weekend because of the weather. and i moved the selector back to 2 wheel drive and and now it wont come out. and suggestions on what to look at and does anyone know if this covered under warranty
Old 12-08-2007, 07:27 PM
toolman05kr toolman05kr is offline
toolman05kr is gaining momentum as a positive member of FTE.
It's coverd by the 3 year 36k warrentee, after that it's your dime unless you have an extended warentee.
Old 12-08-2007, 07:46 PM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.
4x4 high or 4x4 Lo?
Old 12-08-2007, 08:51 PM
6.0superduty's Avatar
6.0superduty 6.0superduty is offline
6.0superduty is starting off with a positive reputation.
if its electric, make sure the truck is in neutral and your foot is on the brake and it should go in or out of 4x4 if everything is working correctly.
Old 12-08-2007, 11:17 PM
msgtg's Avatar
msgtg msgtg is offline
msgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to behold
I concur with superduty. I too had a similar problem with it not coming out of 4L.
In my case, I had to get it on level ground, stopped with it running in neutral, it came right out. I was trying to take it out while still on the hill....it seemed like it wanted the pressure to be off of the front shaft.
Old 12-08-2007, 11:29 PM
thanks for the replys i went outside about an hour ago and started her up and did everything again and low and behold she came right out no questions asked. the only i can figure is she wasnt done playing in 4 wheel drive so she wasnt coming out lol
Old 12-09-2007, 05:20 PM
msgtg's Avatar
Hey, glad it worked out.
Hey, you're another Mountaineer! You need to click the link below and become a WV Chapter member Pal! Go ahead, I'll be waitin for ya!
Joe
4 wheel low 97explorerjunk Explorer, Sport Trac, Mountaineer & Aviator 7 04-29-2016 10:49 PM
4 wheel drive not engaging Rus01 6.4L Power Stroke Diesel 7 12-10-2013 04:03 PM
4 Wheel Drive Wont Work Tyler Scott Bullock 1999 to 2016 Super Duty 6 09-05-2012 02:42 PM
04 Powerstroke won't come out of 4wheel drive? jthussey 6.0L Power Stroke Diesel 12 05-09-2010 12:01 PM
4X4 won't shift out of 4 wheel drive Fat&Bald Offroad & 4x4 4 01-06-2005 09:15 PM
Tags
08, 2001, drive, f150, f250, wheel, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
