O5 wont shift from park - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 12-08-2007, 01:17 PM
ErnieX ErnieX is offline
ErnieX is starting off with a positive reputation.
Hope someone can help,
My son's Escape won't shift out of park when you press on the brake. He says the button on the floor shifter won't depress. Says it feels ike it does when you try to shift without pressing the brake pedal. Anybody have any ideas or suggestions?
Thanks in advance,
EE
Old 12-08-2007, 02:46 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Are the brake lights working?
If not, check the fuse & check the ajustment of the brake light switch.
Old 12-08-2007, 04:57 PM
Thanks for the tips, I'll check it out and post back.
EE
Old 12-08-2007, 08:18 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
You can just press the manual override to take it out of park. This allows it to be driven if the switch is broken. the switch is under the steering column
Old 12-09-2007, 06:44 AM
Dan Robertson Dan Robertson is offline
Dan Robertson is starting off with a positive reputation.
My 2005 shifts on the floor. It has a small round cover (about 1/2" in diameter) on the console, right beside the shifter. The owners manual explains the process. Just use a small screw driver and pry the cover off. There is a white button down in there. Use the same screw driver to push that button. That is the manual over ride and you will be able to get it out of park.
Old 01-25-2008, 04:44 PM
iowaescape iowaescape is offline
iowaescape is starting off with a positive reputation.
I just had this problem with my 05' Escape. They had to replace the fuse panel for $206.
Old 06-13-2008, 07:50 PM
GRNMSTR GRNMSTR is offline
GRNMSTR is starting off with a positive reputation.
Another question about the sifter.... I have an '05 and when shifting from Park to Drive it is really rough and noisey and then even when shifting from reverse to drive it is rough getting it to move. It does move but very noisy almost like the shift rails mechanism is dry. Are there any lube points to lubricate the locking unit (the guides) and rails? I had the transmision flushed and that did not resolve the problem. I am about ready to remove the center console and dig in. Nobody has a Haynes manual in stock to purchase and I have ordered it but still waiting for it to arrive. Leaving next Thursday for a meeting in Michigan and don't want anything to "lockup" while traveling. Any ideas???
won't shift out of park 78150 1999 to 2016 Super Duty 6 12-22-2007 03:12 PM
05 Escape won't shift from park ErnieX Clutch, Transmission, Differential, Axle & Transfer Case 4 12-12-2007 07:21 PM
97 FXLT - push brake pedal -won't shift gears? mlacien 1997 - 2003 F150 5 09-07-2006 05:15 PM
1998 5.4L 4x4 won't shift out of Park HoustonF150 1997 - 2003 F150 4 05-15-2006 07:27 PM
95 aerostar wont shift out of park Loctitez1000 Aerostar 8 09-23-2004 05:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
