'97 e150 hesitation/stumbles between 45-55mph in overdrive - Ford Truck Enthusiasts Forums
Old 12-02-2001, 12:58 PM
jliss1
Guest
Posts: n/a
this problem is noticeable mainly in overdrive i would notice a slight hesitation while my foot is on the gas pedal between 45-55 mph. please help!!!
Old 01-30-2002, 04:15 PM
Parsons Parsons is offline
Parsons is starting off with a positive reputation.
Dear Sir,
My 1997 Ford F150 4x4 (77,800 miles) 4.6l does exactly what you described. I am interested in a solution. I have changed my transmission fluid twice. I believe it may be an electrical problem rather than mechanical. Other than this annoying problem, I am really pleased with this well-built vehicle.
Old 02-04-2002, 06:38 PM
UncBob UncBob is offline
UncBob is starting off with a positive reputation.
Could be Torque Converetr
or
EGR problems
My 93 problem went away when they cleaned out the EGR passages on the INTAKE MANIFOLD side
Old 02-05-2002, 12:06 PM
daw1264 daw1264 is offline
daw1264 is starting off with a positive reputation.
Rule out the EGR system if you aren't setting a service engine code light. The 97 is very picky on the EGR codes, any malfunction in the EGR system sets a P0401 code and the SEL comes on.
Old 02-05-2002, 12:10 PM
cody cody is offline
cody is starting off with a positive reputation.
I have had the same problem and it was solved by replacing the torque converter. And, this seems to be a very common problem with this year of F150.
Hope this helps.
Old 02-11-2002, 02:37 PM
How difficult is it to replace the torque converter? May I ask what you paid for this service?
Hope this helps.
Old 02-20-2002, 04:58 PM
stan808 stan808 is offline
stan808 is starting off with a positive reputation.
Mine is a 99 5.4 and stumbles after about 3400 RPM. It reads 2 error codes, 401 & 402. Is this the same EGR problem??
Old 02-27-2002, 09:55 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
Old 03-20-2002, 04:33 PM
I finally found the reason for the hesitation problem on my 1997 Ford F150 Extended Cab 4x4 Lariat (79,500 miles). Bad spark plug wire, number two cylinder. I replaced the entire spark plug wire harness system. Truck runs great/smooth. I also had the injection system professionally cleaned/flushed.
Old 03-21-2002, 09:53 AM
p_white p_white is offline
p_white is starting off with a positive reputation.
Post '97 e150 hesitation/stumbles between 45-55mph in overdrive
My stumbling at that speed was caused by bad wires and one bad plug.
'05 F150 overdrive shifting problem drew_goeke 2004 - 2008 F150 26 11-20-2016 12:16 PM
What is the easiest spark plug to remove for inspection purposes Alabadyin Modular V10 (6.8l) 6 11-24-2015 01:12 PM
F250 6.0 L Diesel Sputters when going up hill crisk 6.0L Power Stroke Diesel 19 04-04-2015 11:53 AM
2004 6.0 F250 Shaking at 45-55 Speed mgeraci 1999 to 2016 Super Duty 8 06-12-2014 02:38 PM
carrier bearing, checking/replacing? firedad 1999 - 2003 7.3L Power Stroke Diesel 1 08-16-2003 02:12 AM
Tags
1997, 2000, 42l, 45, 55, 55mph, f150, f350, ford, hesitation, mark, mph, od, overdrive, ranger, stumbles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
