High pitch squeel/whistle from engine??
#34
Born2huntwi,
Thanks for mentioning the power steering. I sat in my truck this morning while warming it up (17 F) and the whine started right at startup. I turned my steering wheel and the whine stopped briefly and restarted when I turned the wheel back to center. Every time I moved the wheel it would stop briefly an restart when I returned the wheel to center so my whine must be in the power steering. It will last about 3 or 4 minutes Thanks for the info.
#35
Originally Posted by BigMikeSTX
Born2huntwi,
#36
#37
There several ideas here for the different fixes.
My 99 F150 4x4 is doing this as well. I had a similar problem last late winter and it turned out to be the AC unit. Now 7 months later it has returned. Does the fact that I never refilled the freon have anything to do with it?
Maybe something else is failing this time? Tension Pully?
#38
#39
My 05 4.6l is making that high pitched noise as well. It has been doing it only in the winter months for the last two years. Noise goes away if it gets warmer out. Does not do it at start up however. Hard to listen for it when it is moving. My first impression of the noise was something with the intake though. It is damn loud. Alternator seems to be the same answer from the majority. Is that the final answer?
Thanks
C
Thanks
C
#41
The whistling on mine and i do mean whistling im 100% sure its not a pulley or belt. And only if its 10 and colder like others have stated. Its especially loud at 70 mph. It whistles so loud its actually kinda scary! as soon as i go to 71 or 69 mph it stops. I am pulling out my hair and freezing my butt off trying to figure this one out! Recently ive noticed it starting around 50-52 mph. and as soon as i get to 53 it stops again... wierd!
#43
#44
Well i fixed my Whistling problem!!! Turned out to be a bad PCV VALVE! on a hunch i removed my air intake (stock) once again to double check all gaps and hoseclamps and double checked all vacuum hoses to check for the air leak. When i had the air intake off, i peered down into the throttle body and saw that there was a film of oil in there and i actually saw oil about to drip from the hole where the hose comming from the pcv valve goes into the intake manifold. Picked up a new oem valve, changed it out and NO MORE WHISTLING!!! and it was very cold out when i test drove it on the highway to verify my repair so im 99.99% sure that took care of it. im so happy it was probably the most annoying sound ive ever heard a vehicle make. hope this helps anyone else on their search for the noise!
#45
Not to hijack your thread
I too have a loud whine/ squeal coming from mine, but only upon starting the truck in cold weather about 15 F or below. It only lasts for a couple of seconds and then goes away; the colder it is the longer it lasts. Like this morning it was about -5, started the truck and it whined for about 3 or so seconds then goes away, no noise when driving.
Still sound like an alternator?
2006 5.4 10,000 miles
