Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-08-2007, 11:25 AM
alexjp91 is starting off with a positive reputation.
bed lining floor
i was wondering if it would be a good idea to use bed liner for the inside of the truck on the floor. i just got water in my truck and the carpet is wet. So i was thinking i could just rip it up and use a bed liner. what would be the cheapest one i could get?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-08-2007, 09:35 PM
Keepin It Real is gaining momentum as a positive member of FTE.
You can get a used bedliner for about $25, But they are stiff plastic. How is that gonna work on a cab floor with the hump and varied geometry? You can get a custom fitted full width rubber floor mat for about $100. That would be my choice and a lot less work. Not to mention a much higher level of style.
  #3 (permalink)
Old 12-09-2007, 09:38 AM
tomtoc is gaining momentum as a positive member of FTE.
i think he meant something like line-x, and in that case - YES, you can. seems to be pretty popular to do as well.
__________________
  #4 (permalink)
Old 12-09-2007, 05:02 PM
Oops, sorry. My bad.
  #5 (permalink)
Old 12-09-2007, 08:37 PM
ok. cool. is the spray on stuff expensive? and how hard would it be?
  #6 (permalink)
Old 12-09-2007, 10:20 PM
Green Ford's Avatar
Green Ford is starting off with a positive reputation.
Lots of off roaders do it for that reason. It works fine.
  #7 (permalink)
Old 12-10-2007, 07:11 PM
F250FarmBoy's Avatar
F250FarmBoy is starting off with a positive reputation.
You can go cheap (like most of us) and just get spray cans of undercoating for $3 each.
I used Duplicolor undercoating with "sound eliminator"....whatever, I sprayed my celing with it before I put a never been there before headliner in the '85 and I'm not quite done yet, so I cant say if it helped with sound or not.....
Anyways, Or you can go more expensive with Line-x...Rhino..etc.
IMHO, I think spraying a thick coating everywhere will make the truck more quiet, and if you don't run a carpet, it's so easy to clean off, thats why off-roaders use this method, just hose her down.
__________________
1985 F-350 6.9L -- dually -- ZF SF-42 -- 4.10 -- Flatbed
Dual ram intake/bucket seats/5" stack/manual GPs
  #8 (permalink)
Old 12-10-2007, 07:36 PM
yeah ill go with the cheaper stuff. line-x and rhinoliner is expensive as hell.
  #9 (permalink)
Old 12-10-2007, 11:09 PM
projectnitemare is starting off with a positive reputation.
Spend some serious prep time or it will peel up. The stuff chips pretty easily as well. I spend more time preping the floor than spraying it and I still get some chips in it. About once a year I respray the floor pans.
Matt
__________________
88 Ranger XLT 4x4, 396W stroker, ZF 5 speed, twin stick NP 205, Perry's Fab n' Fiber fenders & bedsides and hood, 8.8 swap, BII gas tank, lifted a bit, 35in ProComp M/Ts.....4 linked Rockewells and supercharged 557 on the way
  #10 (permalink)
Old 12-11-2007, 04:21 PM
what kind of prep do u have to do? peel up carpet, clean floor, what else?
  #11 (permalink)
Old 12-21-2007, 08:04 PM
F350-6's Avatar
Slow Typing
F350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to behold
Use scotch brite, steel wool, etc to scuff the paint. Then clean with an evaporative solvent like acetone (wear plastic gloves). Surface prep will be the key.
The other option would be to find a stock vinyl floor mat from an XL model and install it over the pad of your existing truck. I ordered my 02 this way (Carpet delete option) from the factory.
I'd be worried that the cheaper coatings will make the inside of your truck more noisy.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 270,000 & counting. 6637 w/ Pete's armor. Cold air set up for 6637
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
MORE (Military Online RElay)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
