One More Clearance Lamp Question--punching The Holes
on
I bought the lamps, the wiring harness, and the special nuts that hold the lamps in place from my local Ford dealer this week. I also bought a Greenlee slugbuster knockout punch set for 1/2" conduit, that Greenlee says will make a .89" hole (just a shade bigger than the 7/8" (.875) hole required). I'm sure that there are a couple of electricians here that have used these punch sets for making holes in unpunched electrical boxes. Is this the right tool for the job ??? Greenlee says that this punch can handle 10 gauge or 3.5 millimeter steel. Is this correct ??? 3.5 mm is awfully thick--it's about 1/8 inch. I don't think that the sheet metal on my 2003 F-250 is even near 1/8 inch thick.
So, will this punch do the job, or should I have gotten a 7/8" radio chassis Greenlee punch ????
RON
Will punch thry sheetmetal like butter, leaving a nice burr free edge. I use them for round, square, "D", notch & rectangular holes, sometimes in quite heavy sheet metal. Yes, they will punch thru an electrical box. The "Slugbuster" is the better style, as it cuts the slug in two making it easy to remove from the punch. One word of caution - make sure the initial drilled hole is accurately located, if it's off, the punched hole will be also. If the initial hole is off slightly, it can be drilled a little bit oversized and the punch can be shifted a bit to bring it back into position. When punching the larger holes, (anything with a punch center bolt 1/2"), i usually drill a 1/16" pilot hole, followed by a 1/4" hole. Then I use a 1/2" Greenlee to punch the hole for the bigger punch. Seems to be more accurate when the final hole has to be spot on.
Tell you guys what I'm a gonna do - since a lot of FTE'rs are adding the lights, I'll look to see, I think I have a spare punch - you all verify the correct hole size .....and if I have a spare one, I'll mail it to the 1st one who posts to borrow it. When he's done, he mails it to the next one on the list ... and so on. All I'd ask is an email when each ships/receives it...........
Ah comeon, you don't need anything as expensive as that. This one punch will do the job:
http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=34201429
Any electrician is guaranteed to have one in that size. Just ask a friend.
Bill
Bill
The expensive kit is for guys who are going to use it a lot and want a series of sizes, plus it has the ratcheting tool which works really nice. With the single tool you will just use a regular wrench or socket and turn the screw. It'll last for hundreds of holes, but the bolt does wear out. I have just replaced the bolt with a socket cap screw in a pinch. You certainly don't need the fancy tool to do your project.
BTW, I'll bet you can rent that tool at any good tool rental yard for $5.
Bill
Bill
TexasRebel
1999 to 2016 Super Duty
30
11-24-2010 09:19 AM
