To get this shaft out you will have to do a few things. Unbolt the third member from the beam. From there loosen the long bolt on the back side of the third member near the raduis arm. Give a few whacks with a rubber mallet to break the RTV. After the oil drains take the long bolt out and remove the third member. There will be a C-clip holding the shaft in the diff. Pull the clip and the shaft will slide out. Any parts store should be able to get the u-joints and seals. The cheap jobber u-joints due tend to have fitment issues at times; I have used them with no problems though. The best u-joints will be Spicer, they are about twice the price though. The seals are pretty straight forward, do yourself a favor and replace both sides. They aren't expensive. Be careful when installing them. The pass side is very easy to bend. Reinstall in reverse order. You don't need a diff gasket; it's RTV.
Matt
__________________
88 Ranger XLT 4x4, 396W stroker, ZF 5 speed, twin stick NP 205, Perry's Fab n' Fiber fenders & bedsides and hood, 8.8 swap, BII gas tank, lifted a bit, 35in ProComp M/Ts.....4 linked Rockewells and supercharged 557 on the way
