Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-08-2007, 04:45 AM
fishburn123 is starting off with a positive reputation.
Lightbulb Building My first Engine, Need Advice?
Hi, I have a 95 ford 1 ton dually single cab with a 351w. small block in it. I want to build a bigger engine to go in it. I want to use it as a daily driver, so i want to still be able to run 87 octane. But i want to be in the 300+ horsepower range. does anyone have any ideas To get me started. My knowledge is limited on engines. Any advice would be great.
thanks
J.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-09-2007, 04:46 PM
ReAX's Avatar
Molon Labe
ReAX is gaining momentum as a positive member of FTE.ReAX is gaining momentum as a positive member of FTE.
You have two simple options for legal reasons, you can go with a stroked 351 or a 460. A junk yard 460, honed, and refreshed will most likely be cheaper than stroking yours or buying a stroker motor.
For 87 octane, you can't run much over 9:1 compression or a lot of timing. But ported and polished heads with a good tune and cam should get you over your goal.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #3 (permalink)
Old 12-09-2007, 11:01 PM
How much horsepower will a 460 give me, I want to use the truck to pull trailers with.
  #4 (permalink)
Old 12-10-2007, 01:39 AM
gearhead351 is starting off with a positive reputation.
Quote:
go for the 460 with trialers. I like my stroker 351 windsor but it doesnt have the lowend torque of a big block. Screams like hell up to 5500rpm though
__________________
"Speed costs money, How fast do you wanna go?"
"rumor is you could F**K up an iron ball with a rubber hammer"
  #5 (permalink)
Old 12-10-2007, 08:57 PM
ReAX's Avatar
Molon Labe
It all depends on how radical you want to go. Ford had a set of 429/460 aluminum hemi heads, an aluminum block, a 500+ci cranks, worlds of different cams, electric cooling fans and water pumps, intake manifolds, ect.
Read here and start thinking http://www.carcraft.com/techarticles...ild/index.html
__________________
-MECP 06/27/08
  #6 (permalink)
Old 12-10-2007, 10:58 PM
jamiesan is starting off with a positive reputation.
351 or 460
The 460 is better at pulling trailers since it can produce big torque at lower RPMs, thus wearing less, but since you already have the 351 and the tranny that goes with it ( you'd have to swap trannies too w/460) financially, I'd stay 351. They can produce pretty good power while maintaining dependability.1st off is this an automatic or stick? Anyway, look into a GT40 lower intake ( must be for the 351 the 302's is narrower), an explorer/cobra GT40 upper, either cast iron GT40 heads ( not the "Ps") or Y303s, X303s or the like, a mass air controlled ECU, mass air sensor, map sensor, 65 mm Tbody, good set of stainless or really well coated long tube headers ( headmans/hookers) true dual exhausts with H pipe or cross over. The cam selection will depend on your tranny & rearend gears. & if you're running any gears higher than 4.10s swap'em out, 4.10s-4.56s will PULL and allow the 351 to hit a higher power curve. PS- since so many of the 5.8's parts interchange with the 5.0l there's a huge aftermarket that stays competatively priced and vastly versitile, the 460 stuff is more expensive with fewer options, or at least fewer suppliers. BUT if $'s no object, bigger is always better.
  #7 (permalink)
Old 01-03-2008, 02:34 PM
godblessmud's Avatar
Jack Daniels if ya please
godblessmud is gaining momentum as a positive member of FTE.
The tranny is same..
__________________
Howdy I'm Scott and I'm an adrenaline addict
1990 F150 4X4 XLT Lariat 302 5spd
2000 Ranger 4x2 XLT 244 cid
S_T_G_'_s m_i_n_i_o_n_s:
Public Relations/Recon Dept.
I drink from a cup called fear!
"Hold on tight cause its gunna be wilder than any 8 second ride"
  #8 (permalink)
Old 01-06-2008, 12:23 AM
pcmenten is starting off with a positive reputation.
I think you ought to go ahead with your idea of stroking the 351. And there's a chance that your block will accept a roller cam without drama.
__________________
Best regards,
Paul Menten
  #9 (permalink)
Old 01-06-2008, 01:05 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
HP doesn't tow trailers, TQ does. 300HP is dumb easy with a 351... just let it breath, but it still won't tow like a big block. How big a trailer are you pulling? You'll need to replace the engine and tranny to run a big block, and it'll suck fuel like you won't believe... single digits around town and hauling, so you gotta be prepared for that.
A 5.8 with upgraded intake, heads, cam, and exhaust, computer and fuel system will be pretty respectable, about equavilent to a stock big block, but cheap is not part of the formula. The '95 5.8 is a roller motor.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #10 (permalink)
Old 01-07-2008, 04:12 AM
My thinking with the stroked 351 is that he's be better off selling the truck and buying one with the EFI roller 460 rather than trying to swap engines. He can buy a crate stroker, or, since his block is likely to either be a roller or at least accept a roller conversion, stroke it and make it a roller, he can get most of the torque of a 460 without having to sell the truck. And it should be able to use the stock EFI system.
The common stroker setup uses the stock 351 rods and off-the-shelf 5.0 pistons. That one gets 393 cubic inches. With the roller cam, that should have a lot of torque. There' also a 408, but that usually requires new rods and custom pistons.
__________________
Best regards,
Paul Menten
  #11 (permalink)
Old 01-07-2008, 05:26 AM
littleme13's Avatar
littleme13 has a good reputation on FTE.littleme13 has a good reputation on FTE.
godblessmudd- what do you mean the trannys are the same??? 351w,351c,302 and 289 all share same bellhousing. 351m,400m.429 and 460 share same bellhousing.
as far as the rest, if you have a 1 ton im assuming you haul a big enough load to need it therfor i would recomend the swap to a 460. even with a stroked 351 its not going to last as long as a mild 460 at the same power level. 300hp for a 460 is a switch of the cam and headers. add the cost of a rebuild kit and your lookin at maybe 1000. a tranny depends if you want new, rebuilt or junk yard. but all and all still under the money its gonna cost for a 351 stroked. as far as gas milage, once you put a built 351 in a 1 ton and then tow with it its not gonna give you enough better then a mild 460. and what little it does will not offset the cost of the build and rebuild there after to keep it reliable. reason being. 460 make power down low with right cam usually less than 4k. a stroked 351 is going to have to be at that or better to move the weight that you would need a 1 ton for.
just my .02
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
