i beam suspension
12-08-2007, 02:11 AM
on
i beam suspension
what years had the ibeam? all 1987-1996?
12-08-2007, 08:39 PM
1965-1996 F100/F150, 1965-present F250/350 (2WD).
12-08-2007, 09:05 PM
on
Quote:
thanks i appreciate it
would there be anyways to update the suspension from ibeams to something else on a 1993 f150?
12-10-2007, 09:42 AM
12-10-2007, 10:02 AM
on
Get a f350 solid axle and install. you need to get the mounts and weld/bolt them to the frame. its easier to just get a f250 frame (they are leaf sprung) and put your f150 body on it (thats what im doing)
12-10-2007, 12:31 PM
on
if your talkin 4x4 the ibeam started in 1980
12-10-2007, 01:50 PM
If it's a 4x4 it's not called a twin i-beam, it's called the twin traction beam, or TTB. There are solid axle swaps for the 4x4 to get rid of it, but you're pretty much stuck with it in a 2wd.
12-10-2007, 04:22 PM
Quote:
Originally Posted by lowbudgetcustoms
...would there be anyways to update the suspension from ibeams to something else on a 1993 f150?
Are you looking for double "A" arms with conventional shocks or coil overs?
If so mustang II sytems are pretty much maxed out with the earlier F-100s.
I did run across a photo/article once of a 80s model F series with a mid 70s full-size Ford sedan front frame/suspension grafted to it some how.
Good luck.
12-10-2007, 05:37 PM
on
This interests me as well. I'd love a a-arm/coil over suspension...
12-11-2007, 09:09 AM
Ugh. I don't get that at all. The TIB/TTB is what makes a Ford a Ford for me.
12-11-2007, 09:40 AM
on
One word.. handling.
12-11-2007, 09:58 AM
on
i am not real familiar in this area. The 90 ford f150 i have is a ttb then. does that limit the ammount of lift that can be installed?
12-11-2007, 12:10 PM
Different strokes for different folks, different uses & purposes, thaz' all. Iz' all good...
Thats been the beauty of Fords from the begining. Henry not build just what you want? Then take his parts from elsewhere an doit' yerself.
12-13-2007, 10:31 PM
on
Have one at the shop with 8" suspension lift, its a 94 but still the same lift. and with a 3" body you can get a total of 11"
12-13-2007, 11:40 PM
You don't want to do this for a bunch of different but really good reasons.
