Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-07-2007, 09:18 PM
DesertStorm's Avatar
DesertStorm is gaining momentum as a positive member of FTE.DesertStorm is gaining momentum as a positive member of FTE.
Pcv
Say that a person who had a 2.3L that was "off the road" and didnt have to worry about emissions testing and the like. What would it hurt to blank off the pcv at the intake and install a crankcase breather on the valve cover?
__________________
Member of South Carolina Mudboggers Association
94 Ranger 2wd sittin on 33x12.50's.
93 Ranger 4wd sittin on 39's.
Proud owner of 2008 F-150 4X4!!!!!!!!
Lots of scratches and one bent crossmember already with only 1300 on the odo.
p.s. Dont tell anyone but I use it like a truck is supposed to be used.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-08-2007, 12:31 AM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
What for? The factory PCV set up keeps dirt out of the breather.
  #3 (permalink)
Old 12-10-2007, 11:35 AM
TLyttle is starting off with a positive reputation.
One reason is that the vacuum system will be thrown off, which in turn throws off the computer, fuel injection, and ignition. Unless you are willing to replace or redesign some of these components, just leave the PVC valve in there; it can't hurt.
  #4 (permalink)
Old 12-12-2007, 05:58 PM
all the pcv does is suck oil vapors out of the crankcase via the intake. I was going to blank off the port on the intake and add a crankcase breather filter onto the valve cover port. Just like all the old trucks used to have. No oil vapors going back into the fresh air charge to the motor. Surely it would keep the intake cleaner and have to be worth at least 1/100th of a horsepower. :-)
__________________
  #5 (permalink)
Old 01-13-2008, 08:14 AM
97ranger xlt's Avatar
97ranger xlt is starting off with a positive reputation.
tlyttle is right. it will throw off the computer which in turn throws off a lot of other stuff. in my case the bad pcv caused a high idle.
leave it in there.. better still put a new one on.
my .02
__________________
'97 Ranger xlt super cab 4cyl 5spd 122k
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
